I’m not going anywhere, still have 229 pages to read
I will probably have the Qutest in hand once I can find it for a good deal.
let us know if you need any advice after you got the Qutest. btw, the stock psu works for me.
Heck YES! Tech modding guru all the way yo! I think I've (somehow?I know @DecentLevi REALLY gets into all things audio and tweaks from his Garage 1217 days as well as Feliks audio.
Once he bought a Qutest, it then became a challange for him to make it mo' betta!![]()
I've got mine set at 3V for running direct to planar headphones. The digital volume control in HQPlayer works very well with comfortable listening generally in the range of -15 to -20db depending on the source.It just struck me that Qutest might run without an amplifier. I mean in a similar fashion to using TT2 without an amplifier.
If it was running from a PC with a variable volume output, and Qutest set to 2V or 3V. Then RCA plugs to speaker cables. It might not have enough volume, and it might put too much power drain on the Qutest though.
If I run TT2 directly into speakers at 3V though. It's often too much volume for driving from a PC set at max output. However I do run music at only quiet to normal volumes. TT2 can get loud though, and I barely get near 3V on it. Maybe in very quiet sections in games or video.
Just read through that post you linked, and your post still both confuse me with scant details on which side of which cable have which width and reference of timeframe, the way I read it seems like they lean closer towards 2.1mm connectors. And its' need for a 2.1mm to micro USB adapter added to the confusion.
Per the above I got word back from Ghent Audio they can add JSSG360 shielding and a micro USB connection to the 4S6G cable for just a little extra. @HumanMedia is this still your main DC cable recommendation?
I'm running my qutest 3V into my SPL Phonitor X. Phonitor X runs in a slave through configuration straight out via RCA cables to a Woo Audio WA6-SE. I also exclusively use the green filter. I just set it and forget it. Really super happy!
But why not run your Qutest straight into the Woo Audio?
Thanks for your input. I ordered the above DC cable earlier. Weird how a DC cable could effect the bass quantity, I'll see if it's the same on mine. And yeah please share the info. on the Canadian silver DC cable they swear by when you can find it, just for reference.Yes that’s the one, it’s a custom order, and my recommendation for a great low end DC cable for the Qutest. It does have one downside compared to the Gotham - a slightly rolled off bass. But that is it, it sounds immediately cleaner and more neutral in all other areas and to me, preferable.. Note that the 4S8 has no bass roll off but is too high a gauge for the micro usb. I have also tried the higher priced Neotech found it sounded slow and plodding, maybe due to it not being star quad, so it’s inductance will be 3 times higher.
That is my extent of Low end DC cable experience but I’m sure there is huge scope for doing even better. The Audiophile style guys that moved on from Gotham’s went to much higher priced options, in particular a Canadian sourced Silver DC cable that they swear by. I don’t have details on hand, will have a look later.
But for me right now the 4S6G with JSSG is the best of the low cost options that can fit that microUSB connector. For all other components in my system I am moving to 4S8 With JSSG360 which really are are great. I am content enough with the 4S6G on the Qutest to focus on other area of my system, without jumping up to (much) higher priced options. But if I were to come back to it I would consider DIYing a DC cable based on the VHAudio V-Quad™ Cu21 raw cable with the Oyaide barrel connectors, microUSB connector and copper braid and Teflon tape for the JSSG treatment.
If anyone is wondering about the JSSG360 shielding is all about, it literally creates a Faraday cage around the cable keeping all externally radiated noise out.
Two reasons.
1. In this configuration I get the best of both worlds. I get access to soild state amplification. Sometimes I'm in the mood for lightning fast PRaT and want a reference level sound that the Phonitor X offers. I also have access to both balanced and single-ended headphone outputs.
2. I get the added benefit of the qutest running through the Phonitor X and all its benefits. By benefits I mean its clean voltage rails and it's capacitors. As I use it, Phonitor acts as a pre-amp. I use it in a slave-out configuration. Meaning the signal doesn't get run through the volume pot circuit. It's just passes through. It's the same idea as to why a pre-amp in a two-channel system adds to the overall character and tone before the signal gets sent out to the speakers, or headphones in my case.
I have actually done personal ear testing. Chord qutest straight to the Woo Audio WA6-SE sounds great! Very good. With the Phonitor X it adds weight, depth and a greater 3-D texture. More instrument separation and a deeper soundstage. To my ears, it's absolutely an improvement.
Good question.
Thanks for your detailed response, much appreciated. I am a bit disappointed to hear that the WA6-SE needs help in terms of weight, depth and 3-D texture, but I guess it is what it is.
But I stand by my opinion, to me and for me, qutest to, the Phonitor X to the WA6SE sounds better, than without Phonitor. But, what do I know. Lol
