@AC-12 thanks much for your advice above. I've already been in contact with the owner of Ciunas Audio and it's seeming pretty promising. He even says the current version has two outputs for more than one device. And by SCPSU, are they referreing to the Ciunas Audio ISO-PS?
No worries. Remember, it's just a suggestion and I'm usually off the beaten path in this hobby. So tread carefully. I don't follow the herd, but sometimes it's better to play if safe and follow the herd as others may have success in traditional LPS solutions. But the SC seems like a good balance of value, performance, flexibility and dynamism.
That's great if you can pick JK's brain if he can tell you his thoughts on SC vs LPS.
With the statement above, I think I'm going to give up on the LiFePO4 idea to power the SC and just focus on the SC. SC has lower impedance and faster than the already awesome A123 LifePO4 batteries irrespective if they are mains or battery powered.
I have to look into the dual voltage option. For the SC, it seems the new models are "isolated" so you have dual outputs with no voltage regulator. For the LiFePO4 power supply, only the single output is direct from the battery. The dual output has a voltage regulator. Will need to confirm this is not the case for the SC.
Another issue I didn't consider was the USB power port of the Qutest. For the Mojo, I plan to convert to DC @ 7V so there's no bottleneck:
I think it's fine not a deal breaker if you get a decent HQ DC cable and have it terminated on one end with USB micro connector. These HQ DC cables should be at least rated 2.4A if not 3A from GhentAudio:
http://ghentaudio.com/part/list-dc.html
I don't think a standard USB cable terminated with DC will work well, so you my have to consider a HQ DC cable in this scenario.
I guess your right about a new dual voltage out soon:
link
Yes, same. SCPSU was used early 2019 during the tour. Once the product was official, it was labeled ISO-PS. There's ISO-PS Supercapacitor (new) and ISO-PS LiFEPO4 (old).
