Hi guys.
What ampflier you will recommend pairing this bad boy for driving Fostex TH900/LCD-XC?
Hugo2?
I hope this is a joke, because the Qutest's outputs are only analog and the Hugo 2's inputs are only digital.
If you want to drive HP, get a Hugo 2. Any external amp will degrade transparency - you just can't escape that.
It was indeed designed principally for speaker based systems.
Pretty sure it’s a reply that’s referencing this post:
lol, and you replied while I edited my post, hahaha!You replied before I edited my post. I mentioned that as a possibility.
I dont see a point of Qutest if you are interested to buy a headphone amp at the same time, unless you go for a top end tube
And I don't see the point in buying a Chord DAC if your not going to take advantage of the built in low impedance amp direct without coloring with some external amp/pre-amp, including top end tube.I dont see a point of Qutest if you are interested to buy a headphone amp at the same time, unless you go for a top end tube
Well we are all different. I might say I don’t see the point of buying a Chord DAC if you don’t team it with a powerful enough amplifier to let it unleash the full might and scale of large scale orchestral works. But I don’t say that because we all want something different out of our music and I accept that. I look with quizzical bemusement at people using low output DACs direct to speakers and would never do it myself but if you like it then that’s fine.
