Rob Watts thank you for the info. Very interesting, as always.
Can you help me with DSD-playback, please?
I`m using Qutest via USB from MacBook Pro. Music in DSD256 from nativedsd.com. There are no problems with PCM hi-res, including DXD (24/352,8). Only with DSD. I`ve tried three different players: latest Audirvana, Colibri and Bitperfect with it`s DSD Master add-on.
Colibri makes the worst experience. It plays DSD, but I get a lot of clicks during playback. Audirvana with default settings plays .dsf file good, but Qutest light was blue, not white. Processor usage significantly raised, so I assume some type of conversion was involved. If I set Audirvana to DoP I get white light, but there are clicks during playback. Much less clicks than it was with Colibri, but still.
Creating "Hybrid-DSD" with DSD Master and playing it with BitPerfect is not the most comfortable solution, but sounds better. I still had some clicks, but much less than in previous cases. After taking the USB-decrapifier out of chain, I found that I have less clicks. After changing my USB-cable with more expensive one (AudioQuest Cinnamon) situation improved once again.
Now everything sounds great, but occasionally I might have one or two clicks during the playback of one track. I don`t understand what`s the reason. Is it my USB output to blame, or my software. Unfortunately, I don`t have any other sources, capable of DSD streaming, to check if it`s a problem with my DAC.
