Jul 21, 2018 at 8:24 AM Post #11,642 of 27,001
Hugo M-scaler details are now on Chords web-site. It has "1 x galvanically isolated dual BNC (enables upscaling to the maximum resolution (768kHz from 96kHz data)" I wonder will this eliminate the need for ferrites? It even has DX volume controls so can be connected directly to the Pulse array amplifier.
Jul 21, 2018 at 8:30 AM Post #11,643 of 27,001
The MScaler core within the Blu2, was taking 10A @ 1V
So that is probably a good start point, for estimating how much the standalone version needs.
My Blu2 MScaler (on a not very accurate meter) consumes 13w in idle mode and 23w when fed a USB signal ie when the MScaler is processing. So if the Hugo MScaler consumes about the same then 23W at 15V is 1.5amps which is a bit more than the just the 10amps at 1V for the FPGA.
Jul 21, 2018 at 8:34 AM Post #11,644 of 27,001
Hugo M-scaler details are now on Chords web-site. It has "1 x galvanically isolated dual BNC (enables upscaling to the maximum resolution (768kHz from 96kHz data)" I wonder will this eliminate the need for ferrites? It even has DX controls so can be connected directly to the Pulse array amplifier.
I notice it also says “Auto video and Source selection”. How does it know to auto select video?
And it also says “When partnered with either of Chord Electronics’ 768kHz-capable dual-BNC-input DACs, the Hugo M Scaler sets an astonishing technical benchmark”. Is that right? Aren’t there more than two dual BNC input Chord DACS?
Jul 21, 2018 at 8:43 AM Post #11,645 of 27,001
No mention of the Hugo2, which seems strange.
Jul 21, 2018 at 8:43 AM Post #11,646 of 27,001
I think once you have set each input as to whether you want 1M taps or 2/3M taps, you won’t have to switch it again, unlike me flipping the Blu2 back switch all the time
Qutest, Hugo 2, Hugo TT2 and DAVE accepts dual BNC
Jul 21, 2018 at 8:47 AM Post #11,647 of 27,001
They mustn't be counting the 1x 3.5mm Jack Coaxial 768kHz/32-bit Capable Input on the Mojo and Hugo.
Jul 21, 2018 at 8:48 AM Post #11,648 of 27,001
OK. It’s a small point, but not so sure I would be entirely happy with auto input selection unless you can also force the input. You might say, be listening to some music but watching your tv waiting for a program to start. You’d want to control when you switched inputs.
Jul 21, 2018 at 8:50 AM Post #11,649 of 27,001
But the chord page https://chordelectronics.co.uk/product/hugo-mscaler/ makes no mention of Hugo 2. Is Hugo 2 the poor relative that will only be able to reach 2/3M taps?
Jul 21, 2018 at 8:50 AM Post #11,650 of 27,001
Currently, I just stop playing the music from my USB device. Now, I’m cheap so I usually turn off the UltraRendu so it’ll switch to my video source automatically. Not sure how good the auto detection is since I just don’t push it that hard. Works for my listening habits every time.
Jul 21, 2018 at 11:43 AM Post #11,652 of 27,001
I think I read when the Blu2 came out that as the Blu2 takes over the upsampling work from the DAVE a good portion of the DAVE is redundant once an M Scaler is added. If that is the case, is it imaginable that Chord could bring out a DAVE type DAC but minus the stuff that the M Scaler replaces, with no inputs other than the M Scaler, in an M Scaler type box, at a less high price point. Same argument applies to the HugoTT2 - the M Scaler takes over a good chunk of it's functionality so can does a variant which is DAC but no upsampler or inputs make sense?
Jul 21, 2018 at 2:45 PM Post #11,655 of 27,001
If you take upsampling and taps out of the equation with the M Scaler, what is the effective difference between a Hugo TT2 and a DAVE? ie what does the DAVE have that the TT2 doesn’t and/or vice versa.
And is a DAC imaginable. say in a M Scaler case, that just does the DAC bit and leaves the unpsampling to the M Scaler? In other words no redundant cores doing upsampling, and no redundant inputs.
