Malcyg
- May 5, 2017
Wrong post.
Super mRendu is mR with h/w V1.4?You do not even need to try it, because the result is not anything to wright home about.
With The W4s Remedy Opt/BNC/ Coax clock can give you a slight deeper depht / timing using coax or toslink signal i have found.
But the USB connection is the best and focus on a Auralic Aries or a Super mRendu insted of the regen.
So the chain is Server >UR >IR >DAVE?I also found that the amber regen didn't do much into the Dave. Isoregen however is a big step.
I've just received an ultraRendu 2 days ago and it is a big improvement over microRendu
That seems like a lot of filtering (use this term loosely) before the dac. I'm server into dac. There is a lot of tech in the server why add something more?
I use Roon and logic suggested that I needed to remove the network from my playback system and, once I did, the sound quality of file playback and streaming was improved substantially.
So what is your file playback system now that the network has been removed? Thanks
I was very impressed with the Zenith and am now waiting for a Zenith SE which is a souped up version aimed at removing even more from the the noise areas like power supply, wiring, chassis etc.
Hi, did you find the ISO Regen still added some improvement after the uRendu, or is it now redundant?I also found that the amber regen didn't do much into the Dave. Isoregen however is a big step.
Antipodes audio ds GT USB sounds best as well. Dx even better. No need for any box in between, roon core operates very well.I have been trialling an Innuos Zenith MkII server which runs Roon core and outputs direct to DAC via USB. Usefully, it also has an Ethernet output which means that you can also pursue the end point path if you prefer or if future developments make that a positive gain. That was a key point which led me to the Zenith since most servers only output via one or the other, not both. For now, direct USB sounds best for me.
Antipodes audio ds GT USB sounds best as well. Ds even better. No need for any box in between, roon core operates very well.
