I've been quiet on this forum for probably six months, just reading posts and enjoying my DAVE as I make progress refining my digital signal path (I'm now using the bridged ethernet "direct" connection advocated by Roy (Romaz) on computeraudiophile.com with an SoTM SMS-200).
Anyway, just today I came across the various posts expressing surprise that DAVE's crossfeed setting remains active when using speakers. I was also surprised at this, to put it mildly, and I too tested it out with the Stereophile channel identification track. Sure enough, with crossfeed activated, the speaker channels were not separated at all.
Does this make an audible sonic difference?
Yes, and the difference is VERY significant -- on speakers, the signal is cleaner, the soundstage much better sorted, and the perception of depth greater when crossfeed is set to zero. Unfortunately, I listen to headphones as well as speakers and my crossfeed had been set at 1 or 2 for most of the time I've had my DAVE.
Although I have unending respect for the brilliance of Rob's and Chord's design for the DAVE, Chord's failure to make it clear to users that the crossfeed setting remains active at all times (not just with headphone listening) is a serious issue that should be addressed. At the very LEAST, the manual should be rewritten to reflect the actual operation of the machine. And, in my opinion, the DAVE suffers a design defect because the crossfeed setting is not visible when using speakers (only when a headphone is actually plugged in). This is simply misleading -- how many other users have unknowingly had crossfeed activated while listening to speakers because they (reasonably) assumed the setting only applied to headphones? The result, unfortunately, is compromised sound.
Chord, do you plan to do something about this? It will lead to enhanced appreciation of music and correct usage of DAVE.
