Triode User
Member of the Trade: WAVE High Fidelity
So I recalled that someone here mentioned that he used the headphone out to feed his Stax amp in order to make use of crossfeed.
I got curious and asked Rob. Apparently, when the crossfeed is set, it is set forever, for all outputs (regardless of whether headphones are plugged out, the DAVE is put on standby, or even turned off). In effect this means that crossfeed is a setting like any other, just that you must plug in headphones to set it.
Plug in headphones -> Set Crossfeed -> Unplug the headphones and enjoy the crossfeed settings through the external amp of your choice.
So now I'm using Crossfeed with my external amp, via the RCA inputs!
My friend with speakers apparently has also been using Crossfeed 1 with his speakers![]()
Really? Are you really really sure about that? I was pretty certain the crossfeed was only active when the headphones were plugged in, ie when Dave is in Headphone mode.
