Apr 25, 2017 at 7:53 AM Post #8,356 of 27,035
  Commercial ADC's are not very good or transparent; hence why Davina's ADC.
Davina will also allow redbook conversion to M scaled files; I plan to M scale some of my music to play back on planes with Hugo 2. Of course, its pure digital to digital transfer, so in effect I will be listening to M scaled music without carrying around an M scaler. Perhaps we may see music being re-released as 705/768 kHz M scaled...
Would it be possible to make some M scaled material available as WAV files so that DAVE/Hugo owners can make useful comparisons?
It will be technically possible to do - and I would love to do it. But I don't know what the legal situation regarding clips and copyright. I guess I would need permission from the copyright owner.
It would also be interesting for the copyright owner if you just make excerpts available – sort of promotion. So I really think it is doable, and I would like to get an idea of the M-Scaler.
Apr 25, 2017 at 8:02 AM Post #8,357 of 27,035
Perhaps if you asked someone who makes high quality recordings and has a download store - Hyperion records would be my choice. Then folk could buy the redbook from them, thus satisfying copyright issues, and get the MScaled version either from Chord or again from the same place. I think most of us would be happy to pay. Hyperion make some absolutely outstanding orchestral, choral, and chamber music recordings which they sell as CDs, or redbook downloads or hires downloads for very reasonable prices.
It would be the ultimate comparison! CD vs MScaled CD vs redbook download vs MScaled redbook vs Hires Studio Master vs MScaled Studio master.
Apr 25, 2017 at 8:21 AM Post #8,358 of 27,035
Yes, the DAVE's headphone output blows everything else away. Period.
Does it really?  So, just out of curiosity, which is better  -- a TOTL headphone (e.g. HD800/S, Focal Utopia, etc) driven unbalanced direct from the Chord DAVE headphone amp, or DAVE xlr output to Headamp GS-X Mk2 driving the same headphones in balanced configuration?    Or does it matter?
Apr 25, 2017 at 9:08 AM Post #8,359 of 27,035
I feel sure Rob that Chord Electronics' friends at Metropolis Mastering would both have the authority and ability to produce such a comparison disc/file in under an hour, if they had a mind to.
Apr 25, 2017 at 11:11 AM Post #8,360 of 27,035
The headphones you listed would both be fine with single ended output of DAVE: more than sufficient power to drive them single ended, with fewer components between the analog output and your headphones.   Based on previous posts in this thread, my understanding is that the balanced output has an additional amplification stage, and is capable of driving 10x less current than the single ended output.
I haven't directly A/B tested my HD800 with single ended vs balanced output to an amp (I no longer have a headphone amp), but I have heard an improvement driving a 2 channel amp single ended vs balanced.  For the DAVE, since it is (essentially) natively single ended, if you can get away with it, best to stick with that.
Apr 26, 2017 at 10:44 PM Post #8,361 of 27,035
Is 400HZ power OK with Dave?
I recently received a power regenerator, which outputs 110V 60HZ regular, as well as 120HZ and 400HZ @ 110V.
The 110V60HZ works surprisingly well, the improvement is huge. I'd like to try 120HZ and 400HZ but wondering if this is OK with Dave? I have tried CD player, which power supply is transformer, works great. But for switching power like Dave is using, I have no idea and dare not to try until if someone tells me this is OK @400HZ...
Thanks a lot.
Apr 27, 2017 at 2:35 AM Post #8,362 of 27,035
Given how revealing DAVE really is, it should be well worth the investment to investigate the improvements when a better source component is introduced.
Basically the best clocks out there are DuCULoN and sCLK-EX
https://www.computeraudiophile.com/forums/topic/31572-superclocks/#comment-654721
And then we've gotta power that with a clean source and the output impedance should be very low, Paul Hynes Design should be one of the best and then we've got some options with ultracapacitor banks
http://www.vinnierossi.com/mini/
https://uptoneaudio.com/products/ultracap-lps-1
If you're just looking for a plain and simple audiophile OTG cable since that might be good enough for a flagship Android phone, maybe you could talk to PhilW and find out if Vertere Acoustics were able to do something
http://www.head-fi.org/u/145703/philw
This is the flagship USB cable called Pulse-HB with an optional micro USB config, sometimes they could be willing to make something different such as OTG cables
https://www.audiosanctuary.co.uk/vertere-pulse-hb-double-usb-cable.html
https://vertereacoustics.com/product/digital-cable/pulse-hb-usb-digital-cable/
You could read some impressions of Pulse-HB below
http://www.hiendy.com/hififorum/forum.php?mod=viewthread&tid=92003
http://www.whatsbestforum.com/showthread.php?16660-Vertere-HB-Series-usb-cable
http://audioexotics.vanillaforums.c...e-best-turntable-tonearm-cable-maker-of-uk/p6
http://audioexotics.vanillaforums.com/discussion/13004/skogrand-and-usb-cables
Simply ask PhilW about the possibilities of making an OTG version that's looking just like this one here
https://www.startech.com/eu/Cables/usb-c/usb-2-0-c-b-cable~USB2CB1M
Robb Watts has said that he has found that different sources make little difference to Dave and with the implication that it is not necessary to spend money on the array of gear mention above with the Dave. Likewise I have noticed that he eschews exotic USB cables etc. This is exactly my experience with Dave. Obviously if it makes you feel better then by all means have a go with an exotic cable but the chances are that a well made $20 cable will do the job just as well with the Dave, if not better. I also suggest that people take a big reality check and closely assess the foo content for a USB cable where a 100 hour burn in is suggested.
Apr 27, 2017 at 7:32 PM Post #8,365 of 27,035
it is a major problem to access things with this new upgrade....i used to be able to easily find offerings i had for sale which now is a major inconvenience as is most everything else...i wish they could give us the option to go back
Apr 27, 2017 at 10:09 PM Post #8,367 of 27,035
also on items you have listed for sale why does it no longer give you the option to bump it etc...also the picture i had in an ad no longer shows up..all in all IMHO an awful upgrade
Apr 28, 2017 at 8:13 AM Post #8,369 of 27,035
Hi all, a question for any microRendu + LPS-1 owners feeding their Dave. Or SMS-200 + LPS-1
Have any of you tested the mRendu + LPS-1 combination vs a direct PC USB connection?
What were the differences you heard? And yes I know Rob said it shouldn't matter what USB source etc etc, but just a question for those that have the microRendu or SMS-200 + LPS-1 .
Cheers fellas ! :-)
Apr 28, 2017 at 12:31 PM Post #8,370 of 27,035
I recalled that someone here mentioned that he used the headphone out to feed his Stax amp in order to make use of crossfeed.
I got curious and asked Rob. Apparently, when the crossfeed is set, it is set forever, for all outputs (regardless of whether headphones are plugged out, the DAVE is put on standby, or even turned off). In effect this means that crossfeed is a setting like any other, just that you must plug in headphones to set it.
Plug in headphones -> Set Crossfeed -> Unplug the headphones and enjoy the crossfeed settings through the external amp of your choice.
So now I'm using Crossfeed with my external amp, via the RCA inputs!
My friend with speakers apparently has also been using Crossfeed 1 with his speakers :D
