DaveRedRef-III
With regards to Davina, I hope Chord commission a recording (perhaps a remastering using Davina ADC's) to showcase the technology. That would be something worth hearing back through the Dave I think.
Push the menu button followed by pushing the right arrow for a few seconds until the display blinks. This will switch between PCM and DSD. In my case it only works with the right button not the left one.
Rob, what is most important with the DAVE?
Thank you jazz.
Is the depth of the soundstage of the Dave audible on headphones, or does it need a speaker system?
For Rob Watts : which headphones do you use while on airplanes or indeed anywhere else?
And which portable speakers, if any, do you use in your hotel room?
What is your home hi-fi system which you use with Dave?
Thanks
For those who own the DAVE, please confirm the maximum sample rate through AES. The DAVE manual from the Chord website says 96, but some posts here and elsewhere say 192.
A cheap snare drum might come in handy Rob I would have thought. Twofold really. One the obvious spike transients but two the high resolution required to truly replicate the snare.
This may sound odd but I would also consider testing with recordings of the sea. To my ears the sea lapping on a beach is something ADC's and DACs have a real problem with. There is so much constant high resolution in this sound it shows up the inadequacies of conversion. For me that was a 'stand-out' for DAVE when I first played Quadrophenia by the Who through it. The sound of the sea sounded so much more real than I had ever heard it through other systems including those from Chord.
Anyway just a couple of suggestions fwiw.
Thanks for keeping us in the loop. This is a fascinating project imo.
I'm interested in ordering a Chord Dave. I only found one dealer in the US. Is that dealer the only option?
Bluebird is the only distributer/dealer in the US. But there are a lot of authorized smalltime dealers that you can seek out. I couldn't even begin to tell you how to find them. I believe someone in this thread pointed one out to me. Post your state and I'm willing to bet someone can help.
