DaveRedRef-III
Yes but that depends on my non existent playing abilities! But I think I will get one and thanks for the idea. My son is a grade 2 guitarist, and his teacher is very good, so I will be recording them practicing. At the same time it will give a natural voice test too.
One thing I will try is loud fireworks - the initial crack, the LF bloom, and the way the sound reverbs around the valley will be a good test of depth too.
I will be getting wood blocks though - reproducing the timbre of a wood block naturally is quite a challenge, plus you have the initial transient whack which is really difficult to get right. And its something one can play consistently too.
These initial tests will be crucial, so I can optimise the design of the ADC - in terms of the power of the noise shaper, and in how the system decimates from 104 MHz 6 bits back down to 768 kHz 24 bits. In current ADC's this decimation is done very crudely using simple moving average filters.
The microphones I am thinking of using is the Earthworks QT50 using a Schneider disc. This technique has the benefit of recording phase information as well as amplitude differences. Plus using omni-directional mics to my mind is the best way of encoding depth cues - at least that's the advice I have been given. The QT50 is impulse accurate up to 50 kHz too, and is ruler flat from 5 Hz to 50 KHz.
Rob
You never know you may have hidden talents as a drummer Rob.
Earthworks QT50 sounds a great mic solution looking at its spec, though I have not used one myself.
I like your 'fireworks' idea also.
