miketlse
- May 8, 2016
I'm going to give it about 200hrs burn in time, which I'm sure is overkill (maybe) before I give it a listen.
If you don't listen until after 200hrs burn in, how will you be able to know if the burn in has any effect?
You need to listen at zero hours, for the baseline, and then again after 200 hours, then you can compare the two sounds.
Of course there is always the risk that if you detect no sound difference, you will always feel that you have wasted 200 hours, when you could have been listening to and enjoying your DAVE.
