Dave has a single FPGA, with about ten times the capacity of Hugo's. I don't know where 4 came from, that would have been the DAC 64.
It controls everything, including the display, which means that apart from the USB decoder (which is not on Dave's ground as its galvanically isolated), there are no other digital processing devices. This way I get the lowest possible noise, with everything running from the crystal oscillator. That said, it was a pain creating my own font generator to drive the display.
It uses 5A of current, just to feed the FPGA, so has a big heatsink clamped to the device.
Just to further clarify - Dave is still a work in progress. So further (small) improvements are coming (made some last night). Also we have not released product for review as its not finished, so any impressions are based from shows only.
Another point - something I have only recently got working - there are two different programs for the FPGA function. One that gives the best PCM which is called PCM+, and one that gives best DSD, DSD+. The DSD+ has lower latency WTA for use with video if the latency of PCM+ is too long. PCM+ has Hugo's DSD filter. It takes about a second to switch modes.
The reason for this is because I wanted non decimating DSD filters, and to get the necessary filtering to remove the HF distortion and noise from DSD, required a lot of DSP resources - there is actually 64 cores running to do the DSD. And I could not get all this complexity to fit with the 164,000 taps together.
Rob
