JaZZ
I never use crossfeed with my Hugo. I have tried it but I too find that it messes up soundstage with simply mic'd recordings.
If basses are either on the right side or the left of the stage in the hall, I simply can't understand why one would want to remix them into the center or all over the place as crossfeed seems to do.
My take on crossfeed is that it is artificial, less transparent and a clear step away from how the engineer/producer intended, and not at all accurate to how things sounded live in the hall.
Probably fine for pop and rock where you have no reference to live anyway. But for classical a clear no from me.
There are a few points you seem to misunderstand:
«If basses are either on the right side or the left of the stage in the hall, I simply can't understand why one would want to remix them into the center or all over the place as crossfeed seems to do.»
Crossfeed doesn't shift «the bass» to the center, just the low-frequency content of it.
«My take on crossfeed is that it is artificial, less transparent and a clear step away from how the engineer/producer intended, and not at all accurate to how things sounded live in the hall.»
The most importing thing to consider is that you listen to music recorded for the reproduction through speakers. The recording engineer had no intention to make it sound natural/realistic when heard through headphones. That's why it sounds artificial through headphones: low-frequency tones are unnaturally (up to irritatingly) spread on the two channels. In the everyday world our two ears never get to hear one-sided bass tones, because the shading effect of the head doesn't work with such large wavelengths.
The problem is that «we» are so used to this characteristic (for lack of alternative references) that we tend to miss the fake soundstage content and rate its absence as a loss of spatial information. In my book a good crossfeed almost perfectly recreates a natural tonal balance among the channel separation.
As posted earlier:
Roughly spoken, crossfeed monophonizes low frequencies – the lower, the more crosstalk between the channels, up to 100%. Stage 1 has the lowest low-pass frequency for the crosstalk, stage 3 the highest – it's meant for the most critical recordings (see below).
As you may have noticed, crossfeed only works with headphones. The reason is that 99.9% of the recordings people listen to through DAVE are made for a reproduction through speakers. They're not completely compatible with headphones, although most may be used to the flaws introduced by the mismatch. In the real world it's impossible to hear low frequencies just in one ear. Now almost all recordings contain such one-sided low-frequency signals. They lead to an irritation of the brain or more precisely the auditory cortex. Crossfeed can almost perfectly compensate for that. That doesn't mean the recording is now perfectly compatible to headphone listening, since recordings made for speakers are supposed to be listened in a somewhat reverberative listening room, so they will sound drier than intended when heard through headphones. But the intimacy created that way is a trademark of headphones and not necessarily a bad thing if you like it.
Recordings specifically for headphones do exist – they're called binaural recordings. Among the few I've heard I haven't found one that was really convincing to my ears, though. A general weakness is the lack of perceived frontal sound impact. That may be my ears, since others have reported different experiences.
I had the same struggle with the Hugo, and most of the times had it set to off , or to the green setting.
What cross-feed filter setting are you using mostly Jazz?
You seem to have missed my previous answer:
Great info!![]()
Are you using cross-feed 1 or 3 most of the time?
I don't use DAVE's crossfeed, but my own. All newly acquired recordings get crossfeeded before listening to them. As mentioned, my ears can't bear listening without crossfeed anymore. I use 5 intensities, number 3 (standard nowadays) sounds similar to DAVE's crossfeed 3.
Since Hugo and now with DAVE I could renounce the effort if it were just for listening at home. But I listen to music also on the go and during jogging, therefore it still makes sense – with my FiiO players (of which the X5 II is the center of my home system around DAVE). The Hugo is too bulky for that purpose (and the Mojo doesn't sound better than X5 II or X3 II alone for my taste; moreover it doesn't do crossfeed).
At the price-point asked for DAVE or any other HI FI product above a few thousand dollars I EXPECT full compatibility and ENOUGH POWER to drive any and I mean ANY dynamic or planar headphone on the market!
Anything else is a design fault IMO!
I can understand if products like Hugo or Mojo will not deliver all the power needed for large scale symphonic music at fff .They are after all intended for the portable market. But there is no excuse for having to add a headphone amp to a product like DAVE with any other headphones than electrostats.
IMO absolutely no excuse!
Sorry to be blunt.
I was surprised and disappointed that Rob had not even tested his Dacs with popular planar headphones like HE1000.
I am not a fanboy of any designer or company, neither in the recording industry nor the consumer market.
IMO Rob had all the time he needed to test his supposed STATE OF THE ART product DAVE with any high end headphone on the market instead of the obviously very limited choices he used during the development and fine tuning of DAVE.
With classical music sufficient power is absolutely essential!
Ok Tchaikovsky's 1812 is exceptional even in the genre of classical music and cannons are not generally to be found in any orchestra.
But the dynamic range of large scale symphonic and Operatic music is FAR GREATER than with popular music which in most cases is severally lacking in dynamic range. The dynamic range in basically any of Shostakovich's symphonies for example, ranges from barely audible, to almost painfully loud!!
That said,I was very impressed by DAVE during the few hours I auditioned it.Two good recordings of the 10th and 15th are the live 10th from BSO that I already recommended ,and the 24/192 pcm one of the 15th from the German label Acousense. But if it turns out that I would need to buy an extra amp to drive any dynamic headphone of MY CHOICE, with DAVE I would feel cheated, not happy that they are adding a headphone amp to their product line, as some here seem to be.
Wow, you're an extremely demanding consumer!
I can report that DAVE's headphone output works great (even more than that) with the HE1000, with the HD 800 anyway. I don't own any more demanding headphones for testing. But the power/gain reserve I get from DAVE tells me that except for some exotic designs it will drive all dynamic headphones on the planet.
Your claim also implies that DAVE should do all this with its puristic concept of a DAC output stage driving headphones directly instead of switching additional amplifying electronics to the signal path. Or maybe you just underestimate this approach, which for me is a key feature, like it is with the Hugo, and a reason for the extraordinary transparency and accuracy.
It is impossible to find another combined DAC/ Amp that can drive and control the Abyss / HE-1000 / He-6 like the Dave does what ever price range you look at.
Then the DAVE does not have an amp, so it is just the internal signal if i simplify it you are listening to, and that is remarkable how good it is, if you see it from that perspective.
Then i find it remarkable how close it is to my external amp with 17 Watts and much more on tap at 46 Ohm, it is not a huge difference, just better current drive from the amp, but there is a remarkably big size difference, the amp is like 7 times bigger in volume wise than DAVE.
Then i find it as a hobby to build best possible hifi rigs that got great synergy , so if it was just one product you needed ( Dave ) to buy, then i find it pretty boring as a hobby , when it is also immune to noise , digital cables and sources.![]()
The last bit is a good one! – I bet Christer will add a headphone amp – after extensive, laborious and fascinating search for optimal synergy and the matching interconnects – no matter if necessary or not.
