wdh777
- Oct 15, 2012
Also would you recommend using this with say a gsx mk2 with headphones as I have that already or is the amp sufficient in the Dave?
Do any online retailers in the United States sell these yet? I can't find one. Thanks
Grats, Black looks nice.
I was wondering. Did other people's Dave come with any booklets or anything? That unboxing video showed a packet of papers. I don't think mine came with anything like that.
Yes, it came with a black Manual ,
C13 IEC Power cable
Optical Toslink cable
USB A - USB B Cable
Chord System Remote
I have already like three system remotes incl the black metal casing for the remote ( $799 )
Hmm I got everything but the Manual in mine. Is there a warranty card or something important I need in it?
The sound is from another planet!
Now it is installed, and up running, but i have one question, the display turn off every 15 seconds and then turns on again ?
Does anyone got the same issue ?
Don't worry about the display blanking it is normal. The display gets its data from the flash and I can't read and write to the flash at the same time so I blank the display when saving configuration settings. Actually this problem turned into a useful feature as I know that current settings are being saved when it blanks!
Yes to prevent people accidentally changing modes, you have to keep the right hand button pressed for at least a second when the PCM+/DSD+ is highlighted.
Oh its early for me, I am in Korea!
Yes straight out of the box it will should make fabulous music - assuming of course the rest of the system is transparent.
Rob
