sm60
That’s your opinion and you are certainly entitled to it. I can only speak from my 30+ years of experience listening to digital equipment, starting from the earliest CD playback equipment. As a EE Masters engineer and PhD in CS, when Sony introduced its first Discman portable CD player in the late 1980s, I bought one naively thinking that if the published specs were right, the high end audio problem was solved, at least in terms of the source. When I hooked it up to my grad school audio system, which even then had a very good Spendor SP1 speakers and a Well Tempered turntable, the Sony portable CD player sounded like crap, weak and emaciated. I realized that all the published specs about distortion were just meaningless. Since then I never had cause to doubt my initial impressions. I have lost track of how many high end audio DACs I have used, but in every case, straight through connections to power amplifiers never produced the best sound. When you digitally reduce the volume down by -30 to -40 dB, you throw away a lot of bits and all this talk of transparency goes out the window. Don’t get fooled by published specs in digital audio. Most of the time it is heavily compressed.To make money! There is no way a pre-amp, pair of interconnects, power cord etc. can sound as good as Dave direct to a power amp in a loudspeaker system imho.
I’d love to get rid of all my analog equipment and stream direct digitally to my loudspeakers. Theoretically that should produce the best sound. In practice it doesn’t. I even purchased a pair of Devialet Phantom Gold digital speakers, which are the world’s highest rated loudspeakers in terms of their published specs. They each have a 5000 watt digital amplifier in them and go as low as 15 Hz and can play up to 120dB with vanishingly low distortion. Guess what? They don’t sound anywhere as good as my old antique pair of bookshelf Spendor S3/5, which are derived from the legendary BBC LS3/5s.
The ear is not easily fooled. Published specs like total harmonic distortion seem to have little correlation with how something sounds to our ears. My only reference is the sound of live music. Does a loudspeaker sound in any way like a real concert? Does a voice sound like a real person speaking? Does a piano sound like it does live? Or a guitar? Most high end audio sounds like crap compared to live music. Each day I listen to high bit rate records on Qobuz, and each day I wonder why high end audio systems sound so terrible compared to the live sound.
The only designer who called it as he saw it was the legendary Peter Walker, who designed the Quad electro stats. When asked what he thought of his speakers, he said they were pretty terrible. And this is the lowest distortion speakers you can get on the market even today. We are far from getting anywhere in terms of accurate reproduction of sound. Specs mean very little, sadly. I wish that were not the case. Harbeth designer Alan Shaw used his ears to design his legendary Monitor 40 because every cone material he tried sounded awful to his ears. He finally got a grant from the British government and teamed up with a local university to understand how to measure coloration in loudspeakers. It took several years, but they finally figured out why all the standard measuring tools were all wrong snd designed a new way to measure loudspeakers. This explains why Harbeth outsells every other company in its price range. Their speakers sell for considerably more than anyone else who makes similar speakers. You are paying for all the years of research into loudspeaker coloration. On voices they are simply unparalleled. But if you measure them in terms of total harmonic distortion, they don’t measure better than Quads. But play a voice through them or strings from an orchestra and watch your jaw hit the floor. Mr Shaw had the courage to question conventional wisdom and think afresh. That’s what we need.
