ThanksReversing the dual BNC cables on Dave switches the left and right channels around. It makes no difference on the TT 2 as it recognises the channel identification from the mScaler.
A lot of extra money to solder some wires.Back on topic:
I see 'Wave High Fidelity Storm Reference BNC Cables' received a superb review a couple of days ago (from Positive Feedback), particularly in relation to their use with M Scaler/Dave combo. Congratulations Nick!
https://positive-feedback.com/revie...ave-high-fidelity-storm-reference-bnc-cables/
Or has anyone found a linear power supply that works? I know Rob says they are worst than the switching power supply but then we know that’s what’s causing the RFI to feed into the Dave.
It's not the switching power supply that is causing the RFI to feed into Dave. It's the mains connection. A linear power supply will do the same thing. Optical isolation using the opto DX or cables with appropriately specified ring or sleeve ferrites are the only alternative to a battery supply. Split ferrites can also cause noise. If not into DIY try the Wave cables.
Thanks for the info. Think I’ll stick with battery for now. Wave cables are $1850 for best ones and $1150 for next level down. I haven’t heard any comments on the Stone version. I’ll go hunting for the links and instructions for the DIY cables.
I don’t like the idea of the opto X because then more boxes, cables and need 2 battery supplies. I’m trying to simplify my setup.
When M Scaler is that close to DAVE it really spoils the sound quality. I guess the Naim box will cause similar sound quality problems when it's that close to DAVE.
ThanksWhen M Scaler is that close to DAVE it really spoils the sound quality. I guess the Naim box will cause similar sound quality problems when it's that close to DAVE.
A computer monitor may also cause sound quality problems if DAVE is close.
Once HMS is set up in a system there's no need to see the colours or change its settings. The automatic input switching and the automatic "video mode" make it easy to hide HMS well out of the way. 60cm/2 feet separation between DAVE and HMS is my recommendation.
Free upgrade![]()
No wonder i liked it so muchYour Scaler's in Bypass mode.
Free upgrade![]()
Well it was made to stack with the TT2 so i'm not sure how much of a difference it could make. Though testing them right next to each other and 35 cm apart i think i can hear a slight difference, might just be placebo though.I have my Dave on a glass monitor stand about 6 inches above the mscaler. I read the same thing about keeping them far apart, so wanted to see if that was true. I decided to separate the units about 3 feet apart the other day and but heard no difference.
They’re back to stacked and think looks much nicer that way.
Can't you put HMS on the floor? In my opinion it has no utility being close to hand and just takes desk space.Well it was made to stack with the TT2 so i'm not sure how much of a difference it could make. Though testing them right next to each other and 35 cm apart i think i can hear a slight difference, might just be placebo though.
Expensive footrestCan't you put HMS on the floor? In my opinion it has no utility being close to hand and just takes desk space.
My HMS is in a cupboard.
