Also impossible to connect via browser to poly.audio or poli.audio, don’t know why
Chord Electronics ☆ Poly ☆ (wireless & microSD module for Mojo) ☆★►USEFUL INFO on 1st PAGE!!◄★☆
- Thread starter Matt Bartlett
- Tags
- chord chord electronics mojo poly
ZappaMan
Is glider working?Also impossible to connect via browser to poly.audio or poli.audio, don’t know why
Are you sure you’ve told mpdulxe the correct ip address?
I think you can see the ip address in go figure.
Matt's busy in meetings today so it might be a while until you get a response, in the meantime please report any problems or glitches you find via the feedback form, this will help Chord resolve issues, many thanks for your help.
Hi, not too. When I push the pin I hear the lady but unfortunately she never give the address. Tried with Fing but it doesn’t see the poly even when I push the pin for more than 10 secondesIs glider working?
ZappaMan
Make sure it’s fully charged (my answer for everything!)Hi, not too. When I push the pin I hear the lady but unfortunately she never give the address. Tried with Fing but it doesn’t see the poly even when I push the pin for more than 10 secondes
Yes it, it has been on charge all the night.
miketlse
- May 8, 2016
If you are still using the pin, what version of the firmware are you using?Hi, not too. When I push the pin I hear the lady but unfortunately she never give the address. Tried with Fing but it doesn’t see the poly even when I push the pin for more than 10 secondes
1.0.26, i expect it is the last oneIf you are still using the pin, what version of the firmware are you using?
You art absolutely right, it is now fully charge and all seems to work. Thank you very much for your helpMake sure it’s fully charged (my answer for everything!)
ZappaMan
I knew, sooner or later, the one thing I know would come in handy !You art absolutely right, it is now fully charge and all seems to work. Thank you very much for your help
Waoww loose the last night to understand what happened. Thanks one more timeI knew, sooner or later, the one thing I know would come in handy !
Matt Bartlett
Member of the Trade: Chord Electronics
Thank you for your help however when I left it blank and try it say the password is faulty. I have charges the application MPDluxe but it is not able to find the poly mojo, the light is blue/green but I I have no any communication between iPhone and poly. I read a part of the thread and seen a lot of people have the same problems.
Hi @popof94, you will not get any communication between your phone and Poly if you have not been able to connect your phone to Poly's hotspot. I think your phone will be on a different network to Poly now.
To use MPDluxe you will need your phone on the same WiFi as Poly.
Your Poly is still in hotspot mode as it has flashing blue and green P status light - you can also check what mode it is in by using Gofigure.
If you want to connect your phone to Poly's hotspot then first you need to check whether you have set a password.
Can you go into Gofigure and select device settings to check that you have not set a hotspot password.
If you still get stuck then please email info@chordelectronics.co.uk and we will work this through with you.
PANURUS
- Oct 19, 2015
Could yould confirm me that on android, Go figure is only usable if the bluetooth is working? Have you read it in the manual?
Thank you.
Thank you.
ZappaMan
On iPhone - I think Gofigure works exclusively via Bluetooth.Could yould confirm me that on android, Go figure is only usable if the bluetooth is working? Have you read it in the manual?
Thank you.
The app Uses Bluetooth to talk to poly to setup the config .
Total: 26 (members: 7, guests: 19)
