AudioBear
- Mar 3, 2007
Just remember the GoDive app comes right after GoFigure.
Hi guys,
Whilst I am on the thread can I introduce Chris @BluebirdCRM from our distributor in the North America. He will also be on hand to give support where possible.
I will let him do the introductions and give a little background.
And unfortunately before GoFloat.
Would the case help this. I feel your pain. I would hate a device like this to feel anything other than premium. Mojo is a lovely bit of industrial design IMHO and build quality is superb. Chord seem to have dropped the ball on so many fronts with Poly.I also have been experiencing awesome poly working since 1.17,
But it being bent and uneven leaves me butthurt
On private wifi, using akconnect eveey 30 mins or so, iIhave to reconnect poly to akconnect (just touch it to become render) in ak connect.
I guess a drop in connection of poly/ak connect
Anyone else experiencing this? If so, know of a solution?
Versionn(1.17)
Eduardo, humor aside, be aware that the "dust sprays" can actually cause clogs and moisture (don't shake them) when attempting to clean or dry out electronics. The pros use an expensive machine but look carefully at the various sprays intended to dry out and/or clean out electronic devices.
I don't know if some of the disconnect/drop off issues are related, but give it some consideration. I've seen one spray intended to dry out keyboards cause an actual wet clog that dried quickly and left residue.
The color balls of Mojo and Hugo can collect dust readily, so I carefully keep an eye on them, but moisture, in the attempt to dry or dust, can be a disaster.
getting glider to recognize the poly. Sometimes I get two poly options to pick from in glider, once I hade 4 of them. I keep trying and one of them normally works.
Firmware updates have been no issue.
I've also noticed thisThis “multiple polys showing up” is, in fact, a new bug introduced with 1.0.17 firmware![]()
