Getting a little annoyed already. I have my brand new unit acting in the same way as the old one (at least this one charges fine);
Both Glider/8Player only work for between 5-40 seconds at a time without cutting out and resuming.
Note that this is both on a freshly factory restored Wi-fi hub AND on a 4G hotspot with my iPhone and iPad.
SO: three different setups that have the exact same problem. The only playback mode that works (more or less) issue-free is Airplay with Tidal/Spotify.
I haven’t been able to test MPDLUXE as there are no instructions in the manual on what to do after getting poly to stay in hotspot mode. I have the correct IP address and port in place already.
I would really appreciate some feedback here @Mojo ideas @Matt Bartlett
EDIT: I understand that you cannot foresee difficulties related to a user’s specific listening environment. However, issues occurring on Wi-fi+two separate devices and mobile hotspot again on two separate devices can’t be right.
Please do let me know if I am missing anything. Had it not been for direct Spotify/Tidal playback, this product would have been completely unusable to me. It's a shame that this was not the idea behind buying a Poly in the first place.
@Matt Bartlett @Mojo ideas
I would appreciate some feedback on the above. I am grateful for sending out a new Poly (which fixed my charging related problems) and believe that I have been as thorough as possible in my testing of different set ups/usage environments.
As per the above, I am having difficulties in all usage scenarios other than Airplay with Tidal/Spotify (does not work consistently with any other app) and direct SD card playback with MPDLUXE. Roon works relatively OK.
Please advise- am I doing something wrong or should I just patiently wait for improvements on your end? I find it hard to believe that some people are having a virtually problem-free experience (and I have spoken to such people), while others like me are struggling to find a reliable enough way of using Poly.
Thanks,
Nick
