Yeah work!Maybe this is the way to solve!
Chord Electronics ☆ Poly ☆ (wireless & microSD module for Mojo) ☆★►USEFUL INFO on 1st PAGE!!◄★☆
- Thread starter Matt Bartlett
- Tags
- chord chord electronics mojo poly
I love the sound of the mojo2/poly, but how do you watch a video with the poly without audio delay,/lips not syncing. It's driving me crazy
Edit - decided to use my topping bc3 optical for movies use instead of poly. Hoping it doesn't degrade audio quality too much
My Gofigure app can't finish indexing the SD card on my iPhone. I'm using Mconnect and Poly needs to read SD card for Mconnect every time. Any experience on this?
rwelles
How many songs are on the card? Can another dap index the card properly? I have about 7K songs on a 1TB card, normally it takes about 30-40 minutes to index. Once in a while it will go on for too long, I turn it off and let it go a second round. Then it completes the indexing.My Gofigure app can't finish indexing the SD card on my iPhone. I'm using Mconnect and Poly needs to read SD card for Mconnect every time. Any experience on this?
Thx for your replied. I have less than 7k. Around 200gb from 512gb capacity. I tried it last time, poly stop flashing red and green. I thought it might finished but nothing. And I have to reindex again.How many songs are on the card? Can another dap index the card properly? I have about 7K songs on a 1TB card, normally it takes about 30-40 minutes to index. Once in a while it will go on for too long, I turn it off and let it go a second round. Then it completes the indexing.
captblaze
Totally Power off Mojo/Poly
pull the SD card and delete these files:
art-cache-a.tar
dlna-sdfree.dat
mpd
reinstall the SD card, power up Mojo/Poly
If you are in Everything Else play mode the card will be indexed automatically. If in Roon play mode SD card won't index
Thx! Let me try today!Totally Power off Mojo/Poly
art-cache-a.tar
dlna-sdfree.dat
mpd
I’m
I tried by still can’tTotally Power off Mojo/Poly
art-cache-a.tar
dlna-sdfree.dat
mpd
PANURUS
- Oct 19, 2015
With my galaxy S8, GoFigure can not display the playlist on the SDCARD in the Poly. But it works with 2Go.I’m
For the support of Chord, it is a Samsung problem. My friend, with an another Samsung, has the same problem.
But with MALP or Bubble UPNP, I can use the Playlists.
Thanks for the information. I'm using iPhone so not sure if apple users have the same experience.With my galaxy S8, GoFigure can not display the playlist on the SDCARD in the Poly. But it works with 2Go.
nowadays, I have to wait for sd card loading folder Mconnect. And select the song via Mconnect.
captblaze
if you want a playlist to show in GoFigure, you need to make a playlist file. and place it on the root of the SD card.I’m
Actually I just try to get my index save on GoFigure so I don’t have to wait SD card to be loaded every time.if you want a playlist to show in GoFigure, you need to make a playlist file. and place it on the root of the SD card.
okplayer
- Jan 28, 2016
I have a chord mojo that I purchased with a poly. the gofigure app finds the mojo without a problem.
I recently also acquired a chord mojo 2. The mojo 2 works fine thru the usb but the gofigure app is not seeing the mojo 2? why would the gofigure app find the mojo but not the mojo 2?
okplayer
- Jan 28, 2016
I figured it out the mojo 2 need a more recent 3.0 firmware
Total: 12 (members: 1, guests: 11)
