Chord Electronics ☆ Poly ☆ (wireless & microSD module for Mojo) ☆★►USEFUL INFO on 1st PAGE!!◄★☆
Dec 8, 2021 at 5:11 AM Post #16,576 of 18,821
I’ve updated mine, finally. All seems well so far - I generally use Glider to playback from the SD card - but it seems that the internet radio functionality isn’t working for me now. I know the BBC default streams are no longer available anyway (thanks to the BBC!), but my user-defined radio bookmarks are no longer doing anything. Anyone else tried it?
I may have to reinstall Glider to get corrections to the indexing/listing of a few albums, but that‘s not the new firmware’s fault……presumably.
From my POV, it has been a few small steps forward, and one large step back so far….
Dec 8, 2021 at 4:10 PM Post #16,580 of 18,821
Updated the firmware, but Poly had an issue. Before the update, I removed my SD card. After Poly finished the update, I put back the SD card. Poly started indexing. When it was done, GoFigure showed No Card. I removed the SD card, and deleted all the db/cache files. Insert it back to Poly, and Poly did the indexing again. Then, it recognized my SD card without anymore issue.
For those who has issue, try to delete all the db/cache files, and let Poly indexes again. Hope it helps.
Dec 8, 2021 at 6:29 PM Post #16,581 of 18,821
I will give that a try thanks.
Dec 8, 2021 at 8:45 PM Post #16,582 of 18,821
This worked for me. the Playstore did not show an update to Go Figure and I was not looking at the version number. Once I updated Go Figure, I was able to update the firmware. Thanks for the suggestion.
I also tried to reinstall GoFigure, but still seeing this: "Your Poly is up to date. Version 2.0.0"
Dec 9, 2021 at 6:28 AM Post #16,583 of 18,821
I’m having problem with mconnect after firmware update. Mconnect can’t detect my poly as renderer . I can browse my sd card in mconnect but can’t choose poly as my renderer .
Dec 10, 2021 at 8:58 AM Post #16,585 of 18,821
I initially had this problem with mconnect. It also would not connect to other renderers. I tapped the Airplay icon at the very top left, then selected iPad/Airplay, then selected Chord Poly. Now working.
Dec 10, 2021 at 2:00 PM Post #16,586 of 18,821
Is anybody getting this behaviour of Poly Server since the update? Artist and Genre duplicates with all UPnP apps. Don’t think it happened before the update.
Dec 12, 2021 at 7:27 AM Post #16,589 of 18,821
Can you re-synch in your UPnP app? It certainly seems to help in Glider.
I don’t have this problem with Glider or other MPD apps, only UPnP apps, both mconnect and 8Player. Also BubbleUPnP and Hifi Cast on Android. None have a Sync function as far as I am aware. Therefore seems to be an issue with the Poly UPnP server. I suspect it creates duplicates when artists appear in multi-artist compilations. Bug or annoying feature?
Dec 12, 2021 at 8:37 AM Post #16,590 of 18,821
Another issue with the new Poly UPnP Server. There are no entries for Composer or All Artists under Music.
Edit: Note the ridiculous number of Genre entries due to duplicates.
