silvahr
Both have desktop mode. It's safe to leave both plugged in to mains permanently.
Thank you very much for the information!
Desktop mode is activated by time and not by power cycling H2/2go. Its automatically activated after 24 hours plugged in.Desktop mode H2/2Go:
After playing music, if I leave it powered on 24/7, the frequency light remains on. I have to power down the H2/2Go and power it up again to get the frequency light off.
In what I think is desktop mode, the power button is magenta, and the filter, X-feed and input lights remain on.
Is this correct?
Two things here I can think of from my own experience with UAPP:Hi, I'm interested in using the the Hugo2Go solely as a local library with SD Card data. Can someone tell me - is it possible to use an app such as UAPP to connect to the 2Go such that both SD Cards are loaded simultaneously?
Much obliged.Two things here I can think of from my own experience with UAPP:
1) UAPP is an app that enables a source device (smartphone or tablet) to provide a USB audio feed to a device with USB inputs. The source device contains the music data. I do not believe UAPP can access music files stored on another device such as the SD cards in the 2go. If you wish to play music from SD cards in the 2go then UAPP is not the app for you. BubbleUPnP or similar will do the trick.
2) again as far as I know, 2go can only access its SD cards one at a time and not simultaneously. Why this is so I do not know. You will need to use the GoFigure app to switch between the two.
Not sure I’m following you.I understand not to unplug it. I’m referring to powering it down (while unplugged), while having read to leave it turned on incessantly.
Should the other lights of 2Go be on?
Also If I do not power down, the frequency light (and volume) will stay on. If I don’t use the unit in 3 or 4 days, Hugo is drained.
I do not know about Van Nuys, but I have seen good things written in this thread about the cases from Valentinum.Does anyone know where one can obtain the Van Nuys leather case, as seen below? The wallet thing, I can see on their site, but despite my best detective attempts, I cannot see the model number or indeed any sign of this fine looking case. Thank you.
He is based in Kyiv, and there was news a few days ago about experiencing difficulties at the moment?I do not know about Van Nuys, but I have seen good things written in this thread about the cases from Valentinum.
You can search this thread for "Valentinum" to find out.
Probably. I did not realise he was in UkraineIs he the Guy based in Ukraine, who posted a few days ago about experiencing difficultés at the moment?
Like you, I couldn't find anywhere to purchase this case.Does anyone know where one can obtain the Van Nuys leather case, as seen below? The wallet thing, I can see on their site, but despite my best detective attempts, I cannot see the model number or indeed any sign of this fine looking case. Thank you.
Thanks, it's a mystery. I may well just order the Van Nuys sleeve case itself, though I'd love to have the leather case with it.Like you, I couldn't find anywhere to purchase this case.
The only idea I had was to contact the company directly. It looks like it was available on the Japanese market for a time. Maybe one of our Japanese members could assist? I think VanNuys is based in Japan.
I ended up with Valentinum's case and a Chord official case. I ordered the Chord case with the loops and ended up with the non-loop version. I suppose I could've complained, but realized I'm unlikely to walk around with the combo.
