brintamatic
- Jan 21, 2017
Thanks. So basically no workaround? I unfortunately got a dedicated PC during my time off of Roon so it was a brand new install.
https://www.head-fi.org/threads/cho...-pdif-adaptor-official-thread.925464/page-281Hey guys - I'm sorry if this has been talked about already but I took a long hiatus from Roon when my annual subscription ended. Up until then, I was enjoying the 2Go with Roon. After trying some options that were mentioned on here like Audirvana (which I never could get to connect to my 2Go or the iPhone app), I gave up and decided to re-up with Roon, only to find out that I can't re-add the 2Go as an audio device (saying the manufacturer has not yet completed certification). The only way I could get this to work is adding it using Airplay. Any advice?
Request to become a developer at Roon and they will most likelly set you up lickety-split.Hey guys - I'm sorry if this has been talked about already but I took a long hiatus from Roon when my annual subscription ended. Up until then, I was enjoying the 2Go with Roon. After trying some options that were mentioned on here like Audirvana (which I never could get to connect to my 2Go or the iPhone app), I gave up and decided to re-up with Roon, only to find out that I can't re-add the 2Go as an audio device (saying the manufacturer has not yet completed certification). The only way I could get this to work is adding it using Airplay. Any advice?
Seriously?Request to become a developer at Roon and they will most likelly set you up lickety-split.
Doody
Before I sold my 2Go I had no problem using it and Hugo 2 with Audirvana. Not sure why it would be a problem for others?
I have issues with Chord and MConnect as well. What is weird is that it almost always works when I connect using my iPad Pro but when I use my iPhone, it almost NEVER connects. Audirvana - I couldn't even get my phone to connect to the computer. When I had Roon before, I almost NEVER had issues. The only time I experienced issues is when I was using the Audeze DSP on wireless in certain weak spots in my house.If you're still interested to get Audirvana to work with the 2GO, chase Chord to fix some weird bug in getting devices to get recognised. This isn't just with Audirvana, but it also happens with Mconnect and other apps with UPnP.
Most of the time the 2GO was able to get recognised. But there are some of those moments when you have to force restart the 2GO in order to get it recognised.
I'm late to the game. How do you request to be a developer?Looks like Roon followed through w/ their temporary solution proposal for those of us that applied.
it's in this thread. go back to august (?) when the original announcement happened and step forward. at some point roon opened up this developer option for folks to not be screwed. the deadline was 09/01 but i missed the deadline and they still let me in.I'm late to the game. How do you request to be a developer?
How much does Audievana cost? Does it require a yearly subscription? I hate all of these tacked on yearly fees beyond the primary streaming service.Maybe Roon is better for the 2Go as Roon is also chasing Chord to fix things.
For my other devices, Audirvana works 100% though.
You should have registered with Roon before the cut off and they would have given you developer status, which would have enabled you to use your 2Go. Maybe if you ask them nicely and explain the situation they will sort you out.Hey guys - I'm sorry if this has been talked about already but I took a long hiatus from Roon when my annual subscription ended. Up until then, I was enjoying the 2Go with Roon. After trying some options that were mentioned on here like Audirvana (which I never could get to connect to my 2Go or the iPhone app), I gave up and decided to re-up with Roon, only to find out that I can't re-add the 2Go as an audio device (saying the manufacturer has not yet completed certification). The only way I could get this to work is adding it using Airplay. Any advice?
