No, but ping Valentin via Etsy and ask him. He is usually very open to tweaking stuff. Belt loop can't be too tough.Very smart case.
Can it be attached to your belt at the waist? How do you intend carrying it?
Doody
FYI. Big SQ Delta between roon and audirvana if you are using a roon nuc. Roon sound more full open and organic if using NUC. Tested AUdi via iMac vs roon nuc. Big difference.I spent the day playing w/ various streams sent to my H2Go from a number of players and didn't have a single blip, definitely pleased by this as I've been expecting a more "rocky" experience.
- Apple Music via Airplay
- Qobuz & Tidal (up to 24/192) via Roon
- Qobuz & Tidal (up to 24/192) via Audirvana
- Qobuz & Tidal (up to 24/192) via MConnect
- Flac (up to 24/96) on Micro SD controlled via Rigelian
The only minor and momentary hiccup was with MConnect finding the 2Go DLNA renderer, a quick H2Go power cycle cleared that up.
A whole string of one - the DSX1000 - discontinuedchord has or did have a whole string of network players and music streamers funny it's never mentioned here.
A shot in the dark here, but would that happen if you selected an Airplay device as your Roon endpoint and didn't have an Apple device? I only know cos I made that mistake myself a few months agoHi, im wondering if someone can help me. I can still play my hugo2go using roon but i used to be able to play via bluetooth on my phone spotify. It still says that its playing to the hugo and the track plays but there is no sound. Any suggestions?
Newbie tip: every so often I can’t connect w/ GoFigure (to change cards or WiFi networks) via Bluetooth from my iDevices. Telling the device to ‘forget’ the H2go and then reconnecting seems to fix that— usually on the first try.
Anyone buy this case:
https://www.ebay.com/itm/A6-EASECAS...er-Case-For-CHORD-HUGO2-with-2go/333658536891
and is $100 a good price?
Size? Notch for cable?had this old pelican case hanging around and not being used. fits perfectly..
I couldn't resist and decided to order a 2Go earlier this week. I'm happy to report that, at least initially, things are going well. After upgrading the firmware (to 1.0.3) I used some of the learnings/advice from the folks here during set up. Here are some of the environment particulars.
- UniFi Security Gateway 3P > UniFi Switch 8 POE-60W > (3x) UniFi AP-AC-Pro Access Points
- Roon Server running on an Intel Core i7 Ubuntu Server
I disabled the 2.4Ghz radio on my primary 5Ghz network and created a separate and hidden 2.4Ghz network just for the H2Go to limit interference. I'm wirelessly streaming 24/192 Qobuz (via Roon) with no issues so far and based on the UniFi stats I think I have a fair bit of throughput headroom. Will continue to test in different parts of the house to see if luck holds. We shall see.
I had an m15. Once I opened the h2go and fired it up. Well the difference was Stark. Returned the m15 the next day. I could not believe what I was hearing. Keep in mind I burned the m15 in for 3 weeks and the h2go was straight from the box. I didn't even care about price difference as the square bump was so great
