hptubes
- Dec 5, 2015
Good luck, and we welcome any and all testers and software support personnel to the club. Welcome!
Does anybody else here think it is a bit grim that a prospective buyer of the 2go, a consumer electronics product, feels it necessary to have a background in software and IT support and even then will only go forward on a trial basis?Thanks for all your input everybody, I've decided the time is right to give 2go a trial, my local Hifi dealer will let me test one out before I buy. Wish me luck and I will let you know how it goes.
I have a background in software and IT support so I hope that will help me out.
And you can rewrite the software and potentially make it work!I bet you will love it!
try a HW reset? and reboot router? also simplify pwd just to be sure and retry.... delete network in go figure and retry.New H2go owner here. I’m struggling a bit. I’ve been able to connect to 2Go from iPad or iPhone using GoFigure. I can play from a microSD, or via hotspot or Bluetooth. But I cannot get it to connect to either of my home networks. Does it only support some specific security protocol or set of protocols? I’m able to connect to either network via WiFi on my phone or tablet.
The visible signs are that the 2Go ‘network status’ LED blinks a slow blue, and, in GoFigure, the networks are visible and show ‘full’ strength. But when I select either one of them, the progress wheel just goes round-and-round.
Help please!
I would have preferred a streamer in Qutest range which would fit perfectly, but today there is no such device.I know I've said it before, but the fact that you need the frankendongle 2yu in order to make Chord's kit interwork WITH ITSELF disturbs me greatly. The only excuse for such a horrible-looking thing should be to enable the 2go to work with 3rd party products.
The flagship digital front end, at the moment, would have to be:
2go + 2yu >> Mscaler >> DAVE
The form factor mixture is just nuts. Even with Chord's ridiculously expensive legs you're never going to stack that lot tidily. Even the Mscaler and DAVE by themselves cannot be stacked sensibly.
Add to that the fact that the 2go + 2yu plugged into power and ethernet would have cables flying out of three sides. That is, of course, if you dare operate it while on power.
I really don't get it.
Surely they are going to have to rationalise all this with new products: a streamer and an upsampler in the DAVE format, and a streamer in the TT format.
The temperatures that people are describing in this thread do seem too high. I also read about H2Go when charging gets hot.
I also asked this in the Poly thread, but in case someone in here knows it, how do I get the SD cards in the Poly / 2GO visible in Audirvana? If this is not possible, is this possible in Roon?
