Mark S
- Jan 5, 2011
Re Magnetic cables: its pretty generic stuff. Just make sure its 3A rated ( most of them are). Just search magnetic usb charging cables in the amazon store relevant to your country.
I use an allo Nirvana charger with a usb as well as barrel plug outputs, both rated at 2.8 A each. Plenty of current to charge both the 2go and h2 from a single usb outlet.Your usb charger's current rating will determine if both 2go and h2 get charged simultaneously or not.
I highly recommend the allo Nirvana charger. https://www.allo.com/sparky/nirvana-smps.html
Its the best charger I found in my time with the h2 ( 2years). All other smps chargers added some noise to the stream.Yes, I've tried the Ifi varieties as well, This one just creams the lot. Plus you also get two outputs.
‘thanks. Just picked some up, and the charger too.
