PORTABLE MSCALER: I have been having a discussion with the creator of HQ PLAYER on the ROON forum. Looks like entirely possible BUT also looks like CHORD has crippled the 2GO... read on:
Jussi (HQ Player): "Yes, the MScaler type functionality is in HQPlayer. And NAA endpoint functionality is very light weight and can run on small devices, could probably run on 2Go as well."
Sounds good right??? Unfortunately no... and this would explain all the streaming issues we have... Do not expect to see a fix coming from CHORD... EVER: " However Realistically, only if you use the 2Go via Ethernet. The Wi-Fi chipset in the 2Go is garbage. It is 2.4GHz only and only advertises a single 65Mb/s stream, making it an old/crappy chip even by 802.11n standards. Keep in mind, that 65Mb/s is theoretical max, and real world will be closer to half /two-thirds that. 768k PCM is ~50Mb/s, which has no chance of working reliably on the 2Go’s Wi-Fi. This is a big part of why the folks over on head-fi are reporting problems with the 2Go streaming even at 192k, and 384k being absolutely broken over Wi-Fi when targeting it via Roon."
CHORD this is an absolute disgrace for a device costing this much. You crippled a device that could have been EPIC.
ALSO while we all raise this... CHORD is fully aware of this and remains quiet.... and do not just come out and say: "The 2GO cannot and will never be able to handle files streamed over wireless above 192KHZ".
This company is losing trust.... fast.
TO WRAP... THE 2GO WILL NEVER BE ABLE TO STREAM WIRELESS ABOVE 192 RELIABLY... THIS IS NOT A FW FIX... REQUIRES A NEW WIRELESS CHIP.
CASE CLOSED
I called it a few days ago... this time next year anyone that has not read this discussion will still be complaining about this BS.
CASE CLOSED
