Just tried Neutron, very serious drop out, any recommendation about configuration?After some listening... I found Neutron sounded best on Hugo2go... Even better than AK Connect...
The sound quality is just marvelous with deep black background...
The dynamic range, transparency, and soundstage is really spectacular...
You must try it guys...
Chord 2Go & 2Yu Wired/Wireless Network streamer and S/PDIF adaptor - Official thread
I just turn off Dither, AGP, set resampling to audiophile, turn off ultrasonic filter and generic driver...
I play music from Hugo2go SD Card via hotspot mode...
vourt
- Dec 12, 2010
So it has arrived finally to my country and i can get the 2Go to my H2 now. I just wanted to understand the real benefits of it since i do connect mostly from a laptop with a good (silver dragon) usb c cable, and i can control my entire library trough Audirvana app.
Going out of the laptop is clear to me that audio will improve due to no external connections but i'm afraid to lose the flexibility that my laptop gives me when i brows libraries, adding songs, marking favorites, assigning folders, etc'.
What do you say? does it worth it?
Just a random thought...
If or when a Hugo 3 is released will the 2go be compatible with it?![Thinking face :thinking: 🤔](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f914.png)
![Smiling face :relaxed: ☺️](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/263a.png)
Thanks for your reply, just found that Neutron can run normally in hotspot mode, but not in Wi-Fi mode at homeI just turn off Dither, AGP, set resampling to audiophile, turn off ultrasonic filter and generic driver...
And why the track order is totally wrong in Neutron? How can I make the track order back to normal?I just turn off Dither, AGP, set resampling to audiophile, turn off ultrasonic filter and generic driver...
miketlse
- May 8, 2016
Hopefully yes.Just a random thought...
If or when a Hugo 3 is released will the 2go be compatible with it?☺
However not if those posters insisting that the Hugo3 has usb C sockets, have their way (unless owners use cables to connect the 2Go and Hugo3).
I seldom use hotspot mode, but now testing for a period of time with Neutron apps, really seem hotspot has better sound performance comparing to Wi-Fi mode, and also all "pops and clicks" all gone in my case. But of course only access sd card when using hotspot mode. May I ask any user have the same hearing result?
Hotspot mode consume more power than wifi mode, it should be obvious as 2go generate wifi spot by itself
gryffe
- Jun 11, 2014
My connection problems have actually got worse since the upgrade.
Has anybody who had connection problems before the upgrade found the issue to be resolved after the upgrade?
In post 2981 @Matt Bartlett said " We are working very hard behind the scenes to investigate the pops and clicks issue", so in post 2982 I asked if there were any plans to address the network dropouts. As expected there was no reply. The network dropouts have become the (white) elephant in the room of the 2Go, the topic Chord know is a major flaw in this product and want us all to just roll over and be tummy tickled on, in the hope we will just give up on a resolution and be happy to get an albums worth of play before having to recycle the power on H2Go to get a fresh connection. The lack of acknowledgement from Chord on this issue post upgrade is rude and arrogant. So please Matt, acknowledge there is an issue and that may suffice for just now at least.
Edit - should have added. Since day one network dropouts only occur for me while I am charging and playing H2Go simultaneously,no problems when playing without charger connected, hence I know it is not a problem with my network.
Thoughts on HUGO 3 & 3GO.
Integrated - Next gen product needs to be fully integrated headless streamer/dac/amp
Industrial design - Integrated device can be smaller... make this sleek as F.
Tech - more taps and more powerful amp
App - work with a partner that can nail the SW interface... ideally having some kind of HQ player IOS/Android integration onboard for SW driven mobile upsampling would take this to nxt level. Get a JV going here.
Nuff said... the above would simply be a home run.
how does this cover detach????Its from Valentinum shop on etsym Its my third cover for chord dac from him. My full recomendation. My version is his top model but without the handle it has also detachable cover. I dont think its needed in all use cases but good for those who are disturbed by the lights.
can you show some pictures... thanks!
Mark S
- Jan 5, 2011
I use Rigelian. Will try this one too I guess.
I fail to understand how any software sending control signals to H2go to push bits X from the SD Card over to the USB port (NOT transferring to your phone and back) could sound any different than any other software doing the same thing.
Confused,
Doody
Confused,
Doody
Please compare it to Neutron SQ...
Confused,
Doody
I'm confused too... But it's really sounded different...
Try it with free app first such as Bubble UPnP, mconnect Lite, Hi-Fi Cast, and AK Connect...
Play the same music from your Hugo2go SD Card via Hotspot mode.
