gugman
The ear hooks on the M200 are OK as they are memory and you can bend them where and how you like. The hardest thing is fitting tips on those huuuuuge nozzles.
You can bend them for sure but they do not stay in that exact position for a long time, max few minutes and fitting those nozzles are a bit hard thing, but as soon as you cut hooks fitting becomes so much easier, in reality it is very easy after that and nozzles are no issue anymore
