I agree that measurements can add to a review, the problem is when measurements come from as many different un-calibrated and un-corrolated sources as they do, and conditions under which the measurements are made are not kept equal, the idea that they are essential for comparison purposes falls flat. The differences in measurement setups, environmental noise, procedure, etc.. all play a role in results making comparisons invalid if using two different reviewers data and possibly invalid even when using a single reviewers data done at different times. Your example of Tyll was a good one in that he also preached the use of calibrated systems so that comparisons between them was retained. That takes a good bit more than $55 to pull off. Realistically, creating a truly silent chamber in which to conduct measurements so that ambient noises don't play a roll in the outcome is a several thousand dollar proposition. For Us home users, are you really controlling the environment so that the outside noises reaching the measuring device are exactly the same every time? As I write this, I can hear the ice maker, birds chirping outside, and a low hum of a fluorescent that needs a new ballast. The measuring equipment is a small piece of the overall equation if you really want results that lend themselves to comparisons with others results and retain validity.
