Saoshyant
So apparently Rose Technics (makers of the Masya, Mojito, Pudding, Cappucino, BR5, etc) has decided to get into the budget IEM market. https://penonaudio.com/rose-north-forest.html
How do you notice that?Hi
anybody experience driver flex with Zhiyin Z5000 ?
or is it just my unit?
Let us know how they are!Wow, very cool. Always wanted to try a Rose.
from the plasticky clicking noises when you insert the iemsHow do you notice that?
i think it's a sign of driver flex
Yeah, sounds kind of like crinkling or crunching aluminum foil.
Saw them on an Ali seller and was thinking about these myself. Guess he'll have more than 1 person looking for his impressions.Wow, very cool. Always wanted to try a Rose.
It's a well known phenomenom with the ZhiYin Z5000 (and many other IEMs), and is generally due to the way the IEM is vented (allowing positive pressure caused by inserting an IEM to vent and pressure to equalize).
It doesn't usually hurt anything, and lots of headphones and IEMs have flex. Technically, it can cause issues in extreme cases.
It helps if you insert an IEM into your ear slower, and/or use foam eartips.
You need a combination of 2 things to happen before driver flex can occur. The chamber of the IEM has to be sealed such that a change in air pressure outside the unit (inside your ear canal) moves the diaphragm. And you need an ear tip that seals well enough that air trapped inside your ear canal as the IEM gets inserted increases. Then you get flex. Since most foamies are still slightly porous they can help prevent it. Inserting the IEM sideways meaning that you use pressure in one direction to slightly deform the ear tip preventing a good seal for most of the insertion distance and let the air escape can be enough to reduce or prevent it for silicone tips.Okay.....thats the driver flex thing!
Hum, did not the tips used can cause the....flex?
(did not happen to me with my 2 pairs of Z5000)
