Slater
I just scored a Philips A5 Pro for $60 shipped!
Looking forward to hearing them.
Wow! From where?
eBay, complete with box & all accessories. Supposedly excellent condition, except wiring on 1 driver needs resoldered so he was selling 'as-is'. Asking $100, & I offered $60. Repair should be simple.
I need another pair of headphones like I need a hole in the head, but I really like Philips & I've been dying to try out the A5 Pro and Fidelio X2 for a while now.
I've been looking for a deal on an X2 for a few years now with no luck. Hopefully something will pop up soon.
I wonder how much better the X2 are over the 9500S
I've only compared the two once in a store but at that time I found the X2's to be on a different level. It definitely has a fuller sound with much better bass impact, it's also considerably better built (material wise).
Also: the best pairing I've ever heard with the is the Burson V2+ so given the family resemblance between your Air and the V2+ it'll probably be an excellent match.....
They are the Sony MDR 10RBT's. Originally 40mm drivers. I'm not exactly a bass head, but I do like slightly elevated bass with an overall neutral sound signature.
I don't know exactly how I'd even remove the driver from the casing. It's put in very weird
Usually they're glued in with a thin layer of glue. If you don't care about destroying the stock drivers, it will be infinitely easier. You can also use an xacto to CAREFULLY cut the glue. The trick with the xacto is to only cut the glue and NOT the plastic frame holding the driver.
As far as a new driver, if you want the same drivers, you can get OEM replacement parts from Sony: https://esupport.sony.com/US/p/model-accessories.pl?mdl=MDR10RBT
The advantage with that is you would only have to replace the 1 bad driver. It also has a CCAW voice coil, which is an above-average feature. I see from the exploded diagram how weirdly mounted the stock driver is. They obviously got it installed somehow, so you'll just have to take a look and try and figure it out. It may not even be glued in.
Because it's mounted so oddly, you may want to try and stick with the OEM replacement part, especially if you've never modded a headphone before.
The stock driver is 40ohms, so you want to try and match that with whatever you choose. I wouldn't go with anything less than 32ohms or any more than 50ohms. Ask the seller for impedance specifications before you buy.
So if you want to change to a different driver (and you prefer a neutral sound), I've had good luck transplanting the legendary Koss KSC75 drivers into other headphones. You have to cut them apart using a Dremel, and there's an integrated rear frame that you have to preserve as part of the driver. The overall size once you get it all cut down with the Dremel is 40ish mm or so (might be 1-3mm larger depending on how well you shave it down with the Dremel). The price for the KSD75 are only about $15 for genuine ones (Anything you see for $5-$8 is almost guaranteed fake BTW). I'd strongly recommend you get them sold/fulfilled by Amazon (https://www.amazon.com/Koss-KSC75-Portable-Stereophone-Headphones/dp/B0006B486K).
3 other excellent drivers are:
1. This triple diaphragm driver from aliexpress: https://www.aliexpress.com/store/pr...nit-40mm-speaker-unit/923848_32299109199.html
2. This hybrid wool bio-fiber driver from aliexpress: https://www.aliexpress.com/store/pr...ol-pots-earphone-unit/923848_32258256034.html
3. This carbon nanotube driver from aliexpress: https://www.aliexpress.com/item/Top...e-speaker-unit-Bass-artifact/32299546659.html
You can fine tune the amount of bass on all 3 of the above drivers by covering some or all of the hole in the center of the magnet with some masking tape, modeling clay, or bluetac. The more of the hole you cover, the more the bass will be reduced.
Also, besides impedance, you'll need to keep an eye on driver thickness and magnet size. Some drivers are deeper (thicker) than others, and since it's a wireless headphone there's batteries and circuit boards crammed in the cups that you'll have to contend with. Just make sure if you get something non-OEM, to make sure it's the same thicknesss or less as the stock driver or there's a risk it won't fit. Ask the seller for dimensions before you buy.
Finally, when soldering the new drivers, be VERY fast with the iron, and use the minimum heat necessary. Apply the soldering iron for no more than 1 second, or you risk damaging the driver.
Good luck, and let us know how everything works out.
Sounds great. I was looking at the philps citiscape uptown drivers on aliexpress. They have a big plastic ring around the drivers, which I could probably drill the mounting holes onto, for a secure fit, and the large rings could act as a lip for the pads to go onto (as the pads require glue I think to be mounted). I doubt I could get normal 40mm drivers in. Also, the stock drivers sound pretty awful.
Can you elaborate on the sound signatures of the three drivers you posted? They look interesting
Isn't it a good practice to always replace both drivers, or is that only for hi fi speaker pairs?
