JEHL
Used to enjoy my MDR-XB200 for home listening, then the headband snapped altogether. Considering KSC75 as a replacement for home listening but I wonder if there's anything in the sub $30 range that competes with KSC75.
$33 - Xiaomi Mi HiFi headphone (after sale price and coupons)
$6 - 3rd party Mi Hifi earpads from Aliexpress; stripped for their plastic mounting brackets
$3 - Generic Grado Bowls from Aliexpress (perfect fit)
$0 - True open backed mod and driver retuning
Total = $44
Bang for buck = $Priceless
Hi! I ordered these headphones because I broke my moded grado SR60. I was also planing to put the big pads on.
The only thing I thought I would miss was the open back. Could you maybe describe how to mod these headphones to be open backed and how it changes the sound. I poked holes in my sr60 driver to improve the bass response and truly adored how they sounded. I'm hoping that these xiaomi headphones will be a worthy successor.
Also where did you find the $6 3rd party pads, I can only find them for around $10...
Specifically on-ear? Probably not, no.Used to enjoy my MDR-XB200 for home listening, then the headband snapped altogether. Considering KSC75 as a replacement for home listening but I wonder if there's anything in the sub $30 range that competes with KSC75.
I think another possibility was KPH30i with the giant donut pads to transform it into over ear, although I think total would be $38 at that point.Specifically on-ear? Probably not, no.
You could also look at the KSC75 with a headband mod and Yaxi pads, or Yaxi pads for the KPH30i.I think another possibility was KPH30i with the giant donut pads to transform it into over ear, although I think total would be $38 at that point.
Do good sub $40 over ears exist?
I wonder. Can I stretch the clip on the KSC75 so I can drop the Yaxi pads and keep the clips?You could also look at the KSC75 with a headband mod and Yaxi pads, or Yaxi pads for the KPH30i.
For over ears, ISK MDH9000 and its clones are ones that get mentioned these days in that price point, but $10-$15 more would get you a Takstar GM200, which is a Pro 82 with extra bass and a slightly warmer signature.
https://www.aliexpress.com/item/33012705103.html
$60 in the sale starting tonight, and you can use the $6 code in the first posts of the Pro 82 thread to get it down to $54.
The OKCSC ZX-1 is another option in that higher price bracket, but probably needs a pad change and an EQ, assuming you can tolerate the peaks in the lower treble: https://www.aliexpress.com/item/32921057857.html
Oh I got quite excited when I found your rec of this xiaomi headphone! I'm searching for a portable, foldable and good sounding pair for a long time under 40 usd (no extra fee below this in my country) Something with good sound quality that I can use for long periods and on the go as well, while not looking like a clown haha.Clamping force is perfect IMO. I have been wearing them non stop for about 6 hours so far, with no hotspots or glaring comfort issues. I only took them off once to take a break for dinner.
The on ear pads aren’t overly hot either, which can be overwhelming in summer with big ass circumaural pads like HM5 etc.
They would be more comfortable with larger pads, but that’s every on ear headphone in the world. I might try to mod 1 of my pairs with Beats pads like I did with 1 of my H1707, but we’ll see how I feel.
Note that since the headband is metal, the clamping force can be easily adjusted if need be.
Sub bass extension is deep. It’s not overwhelming or overly boosted though. For example, one of my goto test tracks for sub bass extension is Crazy by Seal. At 5:20 there is a very deep sub bass line, and the Xiaomi hits it with ease and plenty of rumble.
As far as treble, it’s very well done. Smooth, not harsh or piercing, not overly analytical. In fact, the treble on the H1707 can be hotter due to the ceramic tweeter.
The is a very polite and musical headphone. Tuned for the average consumer masses. They’re not TOTL giant killers though. But they’re a total steal at the $39 price, and I’m definitely going to be using the heck out of them (which I can’t say for a lot of my headphones).
Remember though, it’s closed so it’s got the typical closed in compressed sound. But 100% that’s to be expected, especially with on ear pads and compact ear cups with small internal volume.
I will also mention that I am not using the stock cable. I’m using a custom made SPC upgrade cable. I’ve done all my listening with the ES100 and also FiiO A5 amp. YMMV.
is this the correct listing? The store has like 4 different listings for the same product, quite weird
https://www.aliexpress.com/item/4000861493570.html
I bought the Oneodio studio pro about 1.5year ago, but it's too big and uncomfortable for me, I also didn't like the sound signature. (my brother's thin-foam BT version sounds nicer to me) I had a soundmagic p21 and takstar hd2000 as well, which had cheap build quality and average sound, they are in pieces now lol. I only have a lame sony zx110 at the moment which is a joke even after modding lol, and a Pro 80 which is not suitable for outside use, also with circumaural headphone I struggle to get adequate seal. Do you think the sound quality is comparable to the pro 80? Thanks
I'm seriously considering it, honestly I just wanted to buy some cheap diy earphone stuff but this may override the whole thing. Thanks for the rec! Is the cable regular 3.5mm? Do you think the speakers could be upgraded with aliexpress drivers? (if let's say it arrives damaged or I just want to improve it in the future)I don’t own the Pro 80, so I have no idea how the Xiaomi compares.
But I now have 3 of the Xiaomis (1 pretty heavily modded), so that should tell you how much I like them.
By the way, could you give some basic headphone tuning tips? The Oneodio studio pro is ridiculously V-shaped, midrange is very recessed. Pro80 is much better but a bit too bright and thin for me, the vocals are not very natural because of the too much upper part and the treble is too sparkly, sound a bit like over EQ-d clarity. Needs to relax a bit in the upper half. Do you think these could be improved with non destructive methods, like adding or removing foam between the speaker and earpad or something? I'm new to headphones but tinkered quite a bit with earphones.
