Thomas De Brito
- Oct 4, 2015
Just received my memt x5 this afternoon. I ordered on the 15th testing them out, sound pretty nice so far especially for the price
Clearly seems he is chosing P1.
Ok, it is so interesting , can you tell us which one is superstar now,
SW3
P1
K3PRO
A4. .
Ok. I am continuing to be impressed with the Pinnacle P1 by MEE Audio. I have spent a couple of hours and am just entranced by the sharpness and detail and also the perfect balance of frequecies.
Ever the semi bass head, I keep hoping for a little more. Up until now my most 2 recent go to's have been the LZ A4 and Magaosi K3. Both earphone with prestigious amounts of low end. Well after my listen to the P1 I tried both the A4 and K3. Sorry but neither of them sound correct after listening to the P1. The exaggerated low ends of these simply mask the sound and nuances.
I can't believe the P 1 in contrast. It is just SO detailed ,balanced and NATURAL.
It punches far above it's price.
TWIN
I'm sure the Twin would agree that all 4 of these can be superstars in their respective categories:wink_face:
SWIII is a trebles heads dream.
P-1 is smooth and balanced with just about the right amount of everything across the board. (Excellent power and files really elevate this one)
K3Pro is the low end genius of the group.
A4 is the master of versatility.
With the right player and files all of these can be simply fantastic, just my $.02 YMMV:bigsmile_face:
K3 Pro has better low end than SWIII?
I just received a pair of these the other day and will be reviewing them...eventually. I don't know why they mark them as the **** brand as they're actually from ToneKing. Only put a couple songs into them to ensure they worked but they seems pretty balanced with a light treble tilt. Great detail retrieval. Bass is somewhat customizable due to the dual style nozzle (brilliant design imo) that can accommodate tip-mounted micro-driver earphone tips (like those used on the JVC FXD60/70/80) or more standard tips (thankfully both types are included). Midrange is clean and crisp. I paid around 20 CAD for mine and they're well worth that. Full disclosure: I reached out and arranged a discount so I could get a pair in for review. Wasn't willing to pay full price for an unknown.
They're much smaller than the MEMT X5 and sit more flush with your head. Better fit and finish too, though the X5 is no slouch. It's a solid product.The MusicMaker TW1 (same awesome cable as the Light) or KZ HDS1 would be good options if you simply want something cheap and tiny to sleep on, though(scrap that, they fit like the E107) I personally would recommend something with a flatter profile like the QKZ W1 Pro (not necessarily that model, just something in that style).
I just had to wait a couple of minutes
So, tiny is great, I really think I'm gonna try them if they are at least decent. 22$ won't be too much in this case
QKZ also are on my list, they seem similar to the X800 which I don't use only because of the cable. And the QKZ have a nice cable so they should work just fine.
Thank you very much for you imput, it's just what I hoped to hear!
Much has happened since I came here for the last time...
Well I see now, I found the same IEM from another seller (AK), I hope this one hasn't done anything dreadful yet
https://www.aliexpress.com/store/product/2016-AK-Light-In-Ear-Earphone-5mm-Mini-Dynamic-Noise-Cancelling-Sleep-Headset-With-Sleeping-Earplugs/119089_32752459434.html
In any case, it seems to me that both IEMs have not been a bestseller here
Sleep IEMs
In my neverending quest for comfortable IEMs to sleep on, I stumbled upon these "**** Light 5mm" which are advertised as "sleeping earphone".
They do seem pretty small, but before going for them I'd like to know if anyone of you tried them.
I'd buy them on the birthday sale, but at 22$ they still cost a bit too much to be bought without any review.
https://www.aliexpress.com/store/product/****-Light-5mm-Mini-Dynamic-Super-Bass-HIFI-Sleeping-In-Ear-Headset-Totally-In-Ear-Sleep/519064_32752459315.html
The K3 pro has prestigious amounts of Bass, kept Tightly under control with very good Sub bass extension. It is Present all the time Just like the TK12 (the SWIII's little brother). What IS rather peculiar here, (since I've been listening to the P1), is That the Bass response on the A4 and K3 listened to directly after listening to the Bass on the P1, sound positively Bloated and Loose, and I know Stand-alone they are not. It's just the effect I'm trying to point out about the P1 overall precision. It's uncanny in it's price range, and ONLY a single Driver????
The Bass on the SWIII is only present when called upon. The Sub Bass extension however is EASILY the lowest I have heard from any IEM that I personally have had the pleasure to listen to.
There are Many, Many I haven't heard as well.
TWIN
