Would you say that KC2 is more balanced than HZSound Heart Mirror? I took both.
HZSound Heart Mirror is an upgrade over the KC2 in my opinion, you don't really need both TBH.
I've definitely come to the conclusion that different people's ears coverage of vents on the Moondrop SSR relates to different sound given the large variants in reviews and both love and hate for it, if I spot a cheap tin t2 plus I'll need to compare it, but overall I find the SSR silky smooth and not sibalent or overly shouty at all I've heard the stafields and it feels to me I get 95% of the quality including amazing soundstage/imaging for a far smaller price, and the fast, detail bass is actually a dream to me, much more fun sounding than the standard t2 (a reason I'm on the fence about trying the t2 plus is my ear canals are physically too small for the thicc T2 nozzles which actually hurt even with the smallest tips, so if anyone could verify the t2 plus's nozzles are thinner, please let me know)
It's actually rather sad to me that reviews don't mention nozzle thickness at all, it can make or break an IEM for me.
U can read about Tin T2, BQEYZ KC2, HZSound Heart Mirror. The Tin T2 Plus is near neutralish, but more of a U shaped I would say, due to the boosted bass.
Tin T2 is a bit bass anaemic at the subbass. I got rid of my set a few months back, but I think the HZSound Heart Mirror is a true upgrade over it and the BQEYZ KC2.
HZSound Heart Mirror is neutralish bright, fast transients and good technical performance for a single DD. Needs amping though, don't get it if u have a low powered source. The soundstage is not that good too, but it has very accurate timbre for vocals and acoustic instruments, one of the best I've heard at sub $100. HZSound Heart Mirror manages to get vocals forward without being shouty, a very difficult thing to achieve for a budget single DD.
Tin T2 Plus is U shaped, quite good timbre and tonality. Technical performance is about average. Very smooth and non offensive. It has issues with MMCX connectors though, best to buy from Amazon or somewhere where u can get a solid returns policy.
Read about the TIN series, do you reckon the T2 Plus, with it's U Shaped Sound Signature, but average technical performance, is it a good idea to just jump up to the TIN T4? or to the TRI StarSeas for it's tunable nature (I can get a U shaped Signature too right?) (read your review a few days ago), If all I am aiming for is better technicalities?
PS: The HZSound looks interesting but it is not readily available in my country![]()
Rule of eights?If you're considering the T4, you might as well just save money and get the T2 Plus. For the Starsea, it depends on what source you're intending to use with them as it has a very low impedance of 9 Ohms. Following the rule of rights, your source should have an output impedance of around 1 Ohm or less.
I have both. I concur.If you're considering the T4, you might as well just save money and get the T2 Plus.
If you're considering the T4, you might as well just save money and get the T2 Plus. For the Starsea, it depends on what source you're intending to use with them as it has a very low impedance of 9 Ohms. Following the rule of eights, your source should have an output impedance of around 1 Ohm or less.
It will most likely be used on a Fiio M7 DAP whose output impedance is stated to be <2 Ohms, but I guess it's not 1 Ohm? Do you think I can "trick" the DAP by using an impedance adapter like DUNUs?
what I aim to do is to actually increase the IEMs impedance,, is that even possible?I have no experience with those, so perhaps someone else can advise. As far as I can tell though, those seem to increase output impedance rather than decreasing it.
That is exactly what an impedance adapter will do, such as these:what I aim to do is to actually increase the IEMs impedance,, is that even possible?
https://www.aliexpress.com/item/32839680827.html
It adds to the already existing impedance in the iem, so if you have an iem with 16 ohms and you connect it with the 200 ohm adaptet, it becomes 216 ohms.
You could also try the Ifi iematch: https://ifi-audio.com/faqs/the-iematch-is-not-an-impedance-adapter/
