kmmbd
Hi! Could anyone please give me a word of advise? I want to buy headphones for my PC. I have EVGA Nu Audio that can drive 600 Ohm, so high resistance is not an issue. I look to use it for gaming and some music (I mostly listen to music on newly received Dynaudio LYD7, and that's another reason to change headphones). I was using 5.1 headphones mostly for the best positioning but got tired of their low sound quality. Also they are not avaliable today, the "real" 5.1 headphones concept is dead. Virtual surround looks fine now so I want to give a stereo headphones a try.
However, gaming headphones are usually just bad, so I wish to get a better quality music or studio full size headphones and a separate mic. I believe I need headphones with detailed sound, fast transient response, balanced sound (a bit of rised bass is fine though, if it won't spoil midrange). No gaming features are required, sound card will provide those.
What can you recommend in the below 100 USD price range? Is there anything decent at all?
There aren't very many good options in this budget range. If you want closed-back, the two best options (IMO) are Takstar Pro82 and Creative Aurvana Live. In case of open backs, there is only one: Philips SHP9500 (you'll likely need to apply some PEQ to get the best out of it but it's not too much of a hassle on desktop). You can also check out the legendary Koss Porta Pro X + Yaxi Pads. Fantastic combo but some are not fond of the looks.
