Slater
Spiral dots were the best out of the ones i tried.. I also remember @peter123 having iterated the same thing when i asked this very question ages ago.
Ok Thanks
I use Auvios
Ok Thanks
Easy pick would be the KZ ZS7.Right, but 250$ too much for me in Brazil. Any on lower value?
Great, i will see these ones
Difficult question lol
Very good description of a good bass
Right, i will see, i'm sensitive to treble, like more warm sound with bass, not muddy, but not bright.
I also settled on auvios.Anyone with the **** ****. what tips are you guys using? Thanks
KZ Starlines for me.
Which iems do you like that you just bought?
You guys need the fender sureseal tip
Some quick feedback - I ordered the ZS10 Pro because of your recommendations here and have been using them for monitoring - guitar only so far. I have foam tips on there and the isolation is just sufficient for playing with a not particularly quiet drummer.
I've also been using the C10 with foam tips - isolation is a bit less than the ZS10, but still sufficient if you don't play with the drummer from hell.
And guess what? I LOVE the balanced V sound signature on both of them. Don't know if I'll be able to go back to a truly neutral IEM after this. The upper mids on both models are brought forward with foam tips as opposed to silicone tips, and they provide more than enough definition in the upper midrange for me to hear my guitar very well in the mix, even if I don't have a separate aux send for monitoring.
The entire mix sounds nice and detailed, but also thick and chunky. The slight lack of isolation that I thought would bother me lets a little sound from my amp bleed through, thickening up the guitar sound in general and making everything sound like awesomeness.
I feel like a C16 or AS16 may be too anaemic in the bass department after these... I'll have to order at least the C16 regardless though - let's see how long I can stave off my curiosity.
So thanks for all your suggestions and help so far guys and gals! You've made me quite happy
+1 for Spiral Dots!Spiral dots were the best out of the ones i tried.. I also remember @peter123 having iterated the same thing when i asked this very question ages ago.
Ok Thanks
Yes they can nowCan they be purchased separately? I thought they only come with some of their IEMs.
