bemymonkey
- Feb 24, 2007
The New Bee (which I use on the ZS10 Pro) are listed as 4.9 mm
These? https://www.aliexpress.com/item/328...chweb0_0,searchweb201602_8,searchweb201603_60
So: Any ideas for a neutral IEM that has significantly better isolation? I'm mostly looking at the Shure lookalikes, since isolation with the SE215/315/425/535 were always fantastic every time I used them (before I discovered ChiFi a week or two ago I was about to buy an SE535).
Any other suggestions for neutral Chi-Fi IEMs with good over-the-ear comfort, a low profile inside the ear and good isolation?
C10 is far from neutral but more power to you if it floats your boat.For on-stage and isolation, all-BA is a good bet. CCA C10 is indeed pretty neutral and good for mids. You could also do a lot worse than the AS10 (though a bit bulky) or the BGVP DM6.
Never said the C10 sounds bad. But I really dislike people spreading misinformation around. The C10 might have a 'balanced' sound but it is so far from 'neutral' it's not even funny.C10 has pretty colored sound signature to me but its not necessarily a bad thing, definitely more balanced sounding than many others. It doesnt always have to be flat-out-flat.
Have anyone bought Tanchjim Blues yet? I decided to take a risk and ordered them today, there is no single review available yet... It would be interesting to hear thoughts about them.
Right back at you! ...Cheers!Thanks Clear! I am very happy being one of the first lucky people to have bought the DQ4's. They really are something special for sure. Thanks again for your review and thoughts on them, as you were the one to push me over the edge to buy them. Cheers!!
Even though they state 50 ohms, I can honestly say that they are easy to drive! I've tried them on my DAC, MP3 player, digital and analog AMP's, and my phone and they can easily sound loud and clear with very little effort to volume. Personally, with the premium sound and features, including the built in selective tuning modes, they are my personal best!@1clearhead do you know if the magaosi dq4 are easy to drive from weak sources? its stated that its 50 ohms .. can you verify that? are they hard to drive?
Have anyone bought Tanchjim Blues yet? I decided to take a risk and ordered them today, there is no single review available yet... Tanchjims budget in-ears seem to be on the dark and bassy side but model name "Blues" suggests more balanced sound signature. It would be interesting to hear thoughts about them.
There are some impressions on Twitter by Asian users.
