Nimweth
I am using large Spiral Dots. The wide bore works very well and the shallow profile ensures a good fit.hello fellows, any recommendations for tips to use with the ****'s? I'd like to order some along with them
^^This is my favorite tip with them as well
I feel sorry for You then because most IEMs react differently to different tips SQ-wise and spinfit could not be always best option for best SQ.I'm using Spinfit CP100 for ****. Literally Spinfit on all IEM Best tip ever.
Maybe it's not a SQ issue, maybe they just can't get a seal or sufficient comfort with any other tips. I, for example, almost always prefer multiflanged ones due to fit issues (namely, seal and the retention of IEMs within my ears, especially during jaw motion). And I am also not particularly bothered by minute changes of the signature (though I've also seen graphs of some THD change due to tips) since I tend to EQ most things.I feel sorry for You then because most IEMs react differently to different tips SQ-wise and spinfit could not be always best option for best SQ.
guys any suggestion for Over-ear headphones under $ 100? (sound preference: wide sound stage, more focus on mids, V shape sound )
The focus on mids is the opposite of V shaped. The bottom of the V is where there is a lack of mids.
Do you mean W shape?
Also, by over ear are you talking about IEMs that go over and behind the ear? Or do you mean over ear (circumaural) full size headphones? Just clarifying, because this thread is for IEMs.
Should the thread be renamed? It says
Chinese / Asian Brand Info Thread (Portable Headphones and IEMs)
