assassin10000
I can’t wait for mine to come!
I like the TRN BT20, but after a few hours it starts getting painful to wear. I don’t know if it’s because I wear glasses, or if it’s the preformed ear guides putting pressure on my ears.
So I’m hoping the T1C/QS1 will provide all the benefits with none of the downsides.
Did you try re-shaping the ear guides? I did with mine to better fit my ears with a heat gun (that and rotating the mmcx connectors to face down).
EDIT: if you are going to do this be aware it takes a while for the heat to fully penetrate the stiffer inner guide tube. So be prepared to take a several minutes a side so you don't overheat them either, the outer sheathing can warp if so. Also be careful to not heat up the body where the electronics/battery reside .
