Zerohour88
I'd get something like these for cable-rolling though, lol
Anyone here can compare the ZS6 with the V80?
Really curious about it.
In any case, i have small ears but i'm just curious about this comparison.. i know kz zs6 is not the best for small ears, am i wrong?
I would really like to pick a zs6, just worried about the shape as my small ears already hurted wearing my old zs3
Is that a bad sign? Hahahah
Would you guys like it? (mmcx + 2pins)
I've got the KB1. I think it's the same thing but with the Bluetooth cable. All the BQEYZ stuff punches above its price imo.https://penonaudio.com/bqeyz-kb100.html
KB100is coming said to be good at least here so far... https://touch.facebook.com/groups/1221974387914138?__tn__=CH-R
...but they have done good things so far it seems.
Red/Black FTW by the way!
There is a slight change in the faceplate design, which seems to be how they're doing everything at the moment. There is one OEM and several resellers are selling slight variations or the same thing at the moment (KB1, KB100, NY-06, KC2 etc)^Says it comes with the earphones and tips. No mention of BT. It said "new IEM" "will only be making one color" that they had a vote for. Sounds like the upgrade version of the KB1. Penon sells the KB1 for $10 less. Hopefully Penon is not into scamming buy charging more for just a color change of an existing product while giving impression of a new and better sounding product even if it is only $10 difference.
I think I had asked for a graph accompanying that review in order to get the earphone's basic flavour. The general problem is that, once we go up in price, reviewers less likely have heard the competition...which is crucial for any review as comparisons validate an earphone. And, in this price category, anything sounds much better than our $50 fare...but does it sound good enough for the money?
One of these benchmarks should be the Ultimate Ears 900S ($399 list price). An aficionado reported that you need to spend 1000 - 2000 Euros to get a better sound. The UE900S can sometimes be found on massdrop for $179. It is a 2012 model last updated in 2014, looks cheap and unsexy, is built cheaply with simple looking cables, but it is wonderfully small and ergonomic and it sounds stellar. I bet ya that you won't find any Chifi iem for under $1000 beating it sound wise. I trust in Ultimate Ears to have the knowledge and experience to produce a better sounding earphone than any Chinese shop - in a comparable price range.
I agree with most of your comments but I have not noticed any problems with the mids as you have. The V80 is a very nice IEM, with a warmish neutral signature. I prefer this kind of presentation, at the moment I am listening to the Whizzer A15 pro but I had to do a few things to get them sounding right. I couldn't wear them over the ear as the earpieces kept falling out, so swapped the earpieces and cables and wear them cable down. I used a different cable as the supplied one was too loose. Finally I used Trinity Kombi tips and the sound is excellent with a cool neutral feel. The other IEMs I have with a neutral presentation are the Elecom CB1000, and again I changed the cables and use Kombi tips. These are probably my favorites at the moment.wrote my little write-up review & quick FR graph/measurements on the TRN V80: https://www.antdroid.net/2018/09/trn-v80-heavy-metal.html
The main points of the review:
Comparisons
Tin Audio T2
The T2 has a more analytical, colder sound to it. The bass sounds more linear on the T2 vs the V80, which has a more full and warmer sound to it. The T2 mids and lower treble are excellent for this price range and the V80 is nearly there. Where the V80 excels over the T2 is the extended treble, which gives the upper range frequency extra air and depth.
Tin Audio T2 Pro
The upcoming T2 Pro, again, is more colder sounding than the V80 and shares many of the same comparisons as the T2 vs V80. Where the T2 Pro differs is the upper treble extension. The T2 rolls off in this region, whereas the V80 does not. That said, the T2 Pro extends better with more air, depth, control, and details than the V80. The Pro is the head of the class for me for the budget IEM group.
MiniDSP IDF Compensated Comparison
KZ AS10
Spending a little bit more to get the AS10 over V80 will net you more bass and more mid-range and lower treble details. That said, the AS10 may sound muddy in comparison to the V80 because it has more pronounced bass. It’s usually not an issue on the AS10 but if you were to A-B back and forth, you may pick up on some of the upper bass overpowering the lower mids due to the AS10 having a slightly U-shape/recessed mids – where as the V80 has a more mid-forward presentation. The V80 has more air, though the AS10 is more in control in the mids and treble.
KZ ZSA/ZS6
I am grouping these together because, to me, they are similar in sound signature, with the ZS6 being more extreme on the low and upper ends of the spectrum than the ZSA. The KZ pair is more V-shaped, and with that you’ll have deeper, heavier bass, and harsher treble. It’ll give you a fun presentation vs the V80. I think in terms of technicality, the V80 wins. It is smoother all around and has good detail, even in comparison to the ZS6, which has good detail but too sibilant.
Overall
I found the TRN V80 a good IEM. It has some flaws in it, mainly due to some uneven sound in the mids. The neutral-warm sound is inviting and easy to enjoy though, as is the comfort and look. The package as a whole is a budget IEM that I find myself leaving in my ear for hours without any pain or significant issues in sound. I still find the T2 Pro a better option in this price point, but I’d take this V80 over anything that KZ offers today.
The A15 is nowhere even close to neutral! The Kombi tips would make it more towards neutral than regular tips because they nerf the bass pretty hard so depending on what type of seal you're getting it might be starting to sound neutralI agree with most of your comments but I have not noticed any problems with the mids as you have. The V80 is a very nice IEM, with a warmish neutral signature. I prefer this kind of presentation, at the moment I am listening to the Whizzer A15 pro but I had to do a few things to get them sounding right. I couldn't wear them over the ear as the earpieces kept falling out, so swapped the earpieces and cables and wear them cable down. I used a different cable as the supplied one was too loose. Finally I used Trinity Kombi tips and the sound is excellent with a cool neutral feel. The other IEMs I have with a neutral presentation are the Elecom CB1000, and again I changed the cables and use Kombi tips. These are probably my favorites at the moment.
Are these custom made by a modder, or from a company?
Is there any difference in the 2 interfaces? Like the 2-pin has an extra driver wired up vs the MMCX? Or is it simply to give the choice between using a 2-pin or MMCX cable?
I think you are referring to the original A15 rather than the A15 Haydn pro which is the one I have.The A15 is nowhere even close to neutral! The Kombi tips would make it more towards neutral than regular tips because they nerf the bass pretty hard so depending on what type of seal you're getting it might be starting to sound neutral
Comparisons
Tin Audio T2
Tin Audio T2 Pro
KZ AS10
KZ ZSA/ZS6
Overall
