Changing op-amps on Creative X-fi titanium HD
Sep 21, 2010 at 3:00 AM Post #17 of 19
Im actually on the same boat, now that the HD is for sale in USA I just installed mine upgrading from the normal Xfi Titanium.  It sounds pretty similar, although its slightly lacking bass I think.  Has anyone played with the op amps in these?
Jun 22, 2011 at 10:34 AM Post #18 of 19
fyi, here's creative's page about replacing op-amps
http://support.creative.com/kb/ShowArticle.aspx?sid=85621 said:
- 8-pin
- Single or dual DIP (Dual- In-Line package)
- Voltage Range +/- 5V to +/- 15V
Sep 22, 2012 at 10:21 PM Post #19 of 19
Replaced the OpAmps with cans, used OPA2111 for the duals, and can versions of the same LME 4971's, both as recommended on the guru3d review.  Sounds great.  Had to use some .25" spacers and 1cm long M3 metric screws to put the cover back on because they protrude too far from the PCB.
Mouser had both OpAmps if you are interested.  Used the Brown Dog adapters, very difficult to solder and cut leads but worth the effort.
picts:  http://m34t.net/OpAmpCans
