- Jan 27, 2006
Does this still apply? ~ I did a bit of a system clean up today (Vista 64) and reinstalled my soundcard drivers according to this and they don't work? Installing just the soundcard drivers works for my computer speakers however once I install Audio Deck for optical out (for the DAC) the computer speakers no longer work... under sounds they are set as default and the audio bar is showing audio is playing but I'm not hearing anything.
Also there is no WASAPI setting in foobar, is this something else?
Current settings:
*UPDATE: I ticked 'Hi sample rate digital output' (192k Hz) in Audio deck and now the sound is coming out both my speakers and my DAC... that can't be right can it?
Originally Posted by infinitesymphony /img/forum/go_quote.gif [size=small]Windows Vista 64-bit and Windows 7[/size] 1. Install the card into a free PCI slot on the motherboard. 2. Plug your amplification device (ex. speakers, receiver, etc.) into the black "Back Surr" jack on the back of the card next to the optical output. [Previous card revision: "Alt. Out"] 3. Download the Envy24 Audio Controller Family Driver version 5.40a linked here. 4. Use Windows XP compatibility mode to install it using Setup.exe (Application) in the Setup directory. 5. Restart the computer. 6. Open Device Manager (Windows key + Pause Break -> Hardware -> Device Manager), find the sound card, and manually update it to the 4.60b XP64 driver. 7. Restart the computer again. 8. Once the drivers are installed, open the audio control panel using its tray icon on the taskbar. 9. Enable 2CH (not High Quality mode) by clicking the appropriate circle. 10. In Foobar, select WASAPI (envy24 speakers) as the output device. |
Current settings:
