TehNomad
- Aug 5, 2008
Thanks decayed.cell, works like a charm.
Is there any way to map it for games and such?
Originally Posted by TehNomad /img/forum/go_quote.gif Thanks decayed.cell, works like a charm. Is there any way to map it for games and such? |
Originally Posted by decayed.cell /img/forum/go_quote.gif Try the PPHS Resampler to 96000Hz |
Originally Posted by PascalT /img/forum/go_quote.gif I think I read the SSRC resampler is actually better than the PPHS one. Try googling it. |
Originally Posted by decayed.cell /img/forum/go_quote.gif Probably. zzbloopzz, does Vista x64 have its own driver for the AV-710? If so, perhaps my trick on Windows 7 will work - then again, I'm not sure if the driver will go down to 44100Hz, the one on 7 only goes to 48000 |
Originally Posted by zzbloopzz /img/forum/go_quote.gif I must say I cannot recall. Was a while ago. I don't think it did but not 100% on that. If I mostly listen to 192+ VBR MP3's... will I even notice any difference? |
Originally Posted by pod_ /img/forum/go_quote.gif hi guys, first post here ![]() I got this soundcard coming and I'm gathering info to set up my pc. Just one question: after enabling the Black Surr (alt out) to work with the wolfson DAC, does it work like a "normal line out" without any pre-amplification? since my amp is broken I'm trying to understand if I can drive my alessandro ms1 directly from the black surr or if I need the amp to be repaired asap. thanks a lot |
