Q16. My understanding is MQA is supposed to be "end to end", therefore:
- Will there be separate analogue and digital masters? In other words, with many analogue (vinyl)
recordings starting off as digital masters what will be the extent of MQA in the analogue signal chain?
- My understanding of the MQA process is that when the files are encoded, corrections are made for "damage" done by the original ADC.
- Again, with the intent that MQA will be present in the very beginning of the signal chain, are the psychoacoustic issues being talked about for digital in the analogue domain also? Why or why not?
A16.
- Generally there is only one core source of the truth in the studio, the final mix, which can then be mastered to a number of requirements, e.g. as second generation for CD, MFIT, HDTracks, Blu-ray, vinyl, etc. If a new recording is being mastered from digital to vinyl MQA is ideally involved in the capture, mastering and playback to the cutting lathe.
- For new recordings or special re-issues, where possible we fingerprint the system and converters used. This can be done for tracks or for mixes. Deblurring the source is invariably right.
- Generally we are trying to drill back to the sound that was heard and approved in the original mix/master, so it isn’t appropriate to compensate for microphones or earlier analogue components unless it is a new recording and the recording engineer specifically wants to do that.
There are also times where addressing the fact that all we have is 2nd or 3rd-generation analogue tape is worthwhile but that’s too complex a topic for this Q&A.
Q30. Can we be assured we get the best masters? (Whatever best is).
A30. MQA Studio could create a tension in the market that may ensure it happens more often than not. Only the labels can decide to make the effort or choice to ensure. Many labels have this already sorted, others appreciate the encouragement.
Q31. What is the value for the record companies to encode millions of old files? (If they will do).
A31. We can’t answer that, other than to say that for most labels, back-catalogue is more than 60% of their revenue.
