Left Channel
The problem is that for full decoding you would need a new device, software decoding is only available on tidal app so far. so unless you spend money on a device with support you are stuck with 16/48 question is are they any better than whats already out there?
As I understood it MQA is like a zip or like flac that your dac (if it has the right firmware) can decode. how can a decoded file sound better than the original unpacked 24 bit master file? A flac file ((of a 16 bit original) also can´t sound "better" than the original 16 bit file, or am I wrong here? It´s just packed and the DAC decodes the file before playing it. hmm, but maybe you know more about that?
There's more to MQA than just making a Hi Res album able to stream. Part of the MQA experience is remastering and using a deblurring circuit to eliminate pre ringing innate in digital recordings, according to Meridian. I attribute the better sound of MQA to this deblurring process.
With MQA software decoding, we get MQA 1x "unfolding" and up to 24/88.2 or 24/96.
With an MQA DAC doing hardware decoding, we would get 4x unfolding and up to 24/192.
Here's more on how MQA works:
* MQA Decoding Explained | AudioStream
* MQA Playback | Bob Talks
I haven't heard anything at 4x. Remastering may be the only reason the 1x Tidal Masters sound better to me than the same tracks in Tidal HiFi, as is often case with hi-res tracks of any kind. I think I've got the facts straight, but can't form an opinion on quality without hearing 4x decoding side by side with the files from the same source material in other formats.
