My issue isn't with the IEMs having noise and I have accepted the fact that this will be something I can't fix regardless with these sensitive IEMs. Needless to say if one is using sensitive IEMs with an amp this powerful then that would be quite silly, but it is important for people to also know that there is a significant change towards frequency responses & damping factor on low impedance 1-3 modes regardless of if you are using IEMs or headphones, especially dynamic driver headphones which don't have flat impedance curves. If that alteration is an enjoyable presentation for you, great! In my case, not so much.I know part of your issue is using extremely sensitive headphones or IEMs along with the RCA inputs. Some good power conditioning or an isolation transformer could definitely be beneficial, but there may still be some residual noise if you're using the same RCA DAC and IEMs.
I believe you are located in Australia? PuraSound in Brisbane carries Keces products. It might be worth seeing if they will offer you a trial period on one of their small isolation transformers like the IQRP-800. Or perhaps they might have something else they carry that they would suggest trying to see whether or not this reduces or eliminates the noise you are experiencing.
My issue is with the headphone itself still having noise floor using XLR output on high impedance (which is the only mode I consider viable as I do not enjoy the effects of low impedance 1-3 options). The only fix in this case would be to switch my DAC to one with XLR out, or a headphone that is less sensitive. Obviously if one had headphones more difficult to power than the Meze Elite, then this is something to be ignored and just enjoy the amazing amp. If one had an XLR based DAC, then the same can be said. Most people should fall into one of these categories, or both.
However, it definitely wasn't something I personally was aware of being a user of the Chord Qutest (which only has RCAs) and Meze Elite (a relatively easy to drive headphone). If I knew about this case initially, I would have reconsidered my amp options as I had no plans of changing the DAC or headphones. I am looking into getting an XLR based DAC now, but I'm sure if others ran into this situation they would be a little frustrated too, especially if they do not have the ability to make another purchase. I'm sure you wouldn't be too happy getting an item like this only to find out afterwards that your previous gear aren't good enough to match it and need more unplanned changes. Wish there can be a fix in this case because the pairing between all 3 of these units (Silver Fox/Qutest/Elites) is unreal, the noise floor is the only thing stopping it from being perfect. Once again, the noise floor is also extremely inaudible and only people like me with OCD towards the smallest imperfection noticeable will ache over it.
I hope this doesn't blow out of proportion and make people turn away from the amp, this is easily the best amp I have ever heard. I don't have much experience with amps however...
Not sure about the small isolation transformers however, those seem way too expensive compared to what I'm willing for pay for them and I would rather just use that budget to find a superior DAC with XLR and just use parallel mode (even if the DAC just costs much more).
