Wow so I tested this song and its the first time I got any sort of stuttering/audio artifacting! Would be interesting to see why this song in particular is causing problems with the all-DSD conversion. Hopefully one of the engineers can take a look and give us a firmware update to fix this weird "bug".
Upsampling, because DSD uses a higher sample rate. DSD64 = 64 x 44.1 or 48 kHz. The bit rate is only 1-bit, not 16 bit however. Instead of a samples representing the volume level at every 1/44,100th of a second, the average of the number of 0's or 1's represent whether the waveform is rising or falling.
Any thoughts on an OG Chord Mojo vs. RU7 comparison?
I love the Mojo, but would appreciate the smaller package of the RU7. My most used IEMs are Audeze LCD-i3 and JVC HA-FX750, and I listen to most any genre except classical. I also value soundstage a lot (and would like to improve on the Mojo's sound stage).
Burning in mine . Very impressed with the sound even out of the box. Happy owner of RU6 as well but getting a different sound signature for a very reasonable budget is a steal for me.
Should we start worrying? Does that mean that one song out of a hundred doesn't let us listen to it?
It would be curious to know if the N7 behaves like this too...
Using the Belkin "USB-C Audio + Charge Adapter" with my Samsung S22 Ultra with any Usb dongle and either Battery or wall charger (getting fast charging)
AFAIK, DAPs had considerable latency because it runs its own OS and the USB connection is unlike a traditional async dac/amp but more like a bitstream. Seems wholly atypical to use a DAP for gaming lol
First OOTB impressions of RU7 are a bit mixed (Pixel 7, Qobuz, UAPP, ie900, 44.1/128DSD). I can appreciate the space and separation, which is pretty unique and a boon for symphonic music, but the SQ is a little flat and can sound quite rough - maybe unforgiving on less well recorded tracks? The RU7 (IMOO) doesn't, doesn't have the OOTB charm of the DC04Pro. I'll burn it in for 100 hours or so and see if it improves.
