Cayin RU7: 1-Bit Resistor Network Dongle DAC /Amp
- Thread starter Andykong
Hi, if someone helps me, I wanted to understand a bit how this "all to DSD" technology works:
1) is there a "better" and a "worse" between switching between DSD64-128-256 or is it just a matter of personal taste/synergies/technicalisms?
2) can it also be disabled or the minimum is DSD64, and if it can be disabled what does it bring about the audio quality?
2) is it true that DSD64 approaches RU7 to a R2R and DSD256 to a delta-sigma?
3) the greater use of current going up with the DSD conversion can create problems only with iPhones or is it better to set a low value for all smartphones and use DSD256 only for PC use?
4) Are clicks on some high settings of the "all to DSD" function due to power problems or are there other implications?
Thanks to whoever will answer me.
Is RU7 available somewhere in EU (except UK)??
How is that headphone? I am thinking to get it too and have it made balanced. 4.4 RU7 balanced will have more then enough power to drive it well.Well, I am using now AKG K612Pro:
General Specifications
Sensitivity (dB SPL/V @ 1 kHz)101
Rated impedance (Ω)120
Audio frequency bandwidth (Hz)12 - 39500
Maximum input power (mW)200
And I have to crank up the volume all way to 86-88 on single ended. I don’t have a balanced cable nor AKG comes with it. It’s soldered into the driver.
Topping is better amplifying.
The Cayin distributor in Germany does not have it in the list yet...Is RU7 available somewhere in EU (except UK)??
It’s actually my first AKG, and it sounds pretty airy, and very detailed. It’s excellent for classical/instrumental. I sell mine anyways cause I use only iems these days.How is that headphone? I am thinking to get it too and have it made balanced. 4.4 RU7 balanced will have more then enough power to drive it well.
https://www.ebay.com/itm/3642651168...Ck2t7qDRPG&var=&widget_ver=artemis&media=COPYMaybe thisIs RU7 available somewhere in EU (except UK)??
Ben86
- Jun 24, 2015
https://hifigo.com/collections/new-arrival/products/cayin-ru7Is RU7 available somewhere in EU (except UK)??
Here you can order EU
I ordered from Hifigo, but they are not honest about availability. They just said that they will ship asap without telling if they have stock or when they will have stock. Before placing the order, they told me that they will ship after 3 days. I should never blindly trust Chinese websites
Same happened to meI ordered from Hifigo, but they are not honest about availability. They just said that they will ship asap without telling if they have stock or when they will have stock. Before placing the order, they told me that they will ship after 3 days. I should never blindly trust Chinese websites
Never again
To cut the bull's head, as I did for the RU6, I bought it on the Cayin site on Aliexpress... at least I have a direct relationship with the Cayin and the RU7 is available, in fact they have already shipped it.
Yes but if I order from Aliexpress, I have to pay customs fees upfrontTo cut the bull's head, as I did for the RU6, I bought it on the Cayin site on Aliexpress... at least I have a direct relationship with the Cayin and the RU7 is available, in fact they have already shipped it.
Just ask to declare 50 euros in value with a message, I did this for the RU6 and I paid 14 euros at customs. 212+14=228 euros for a brand new RU6.Yes but if I order from Aliexpress, I have to pay customs fees upfront
jsmiller58
I feel badly for you that you had a bad experience. I have ordered from Hifigo, Shenzenaudio, and Linsoul many times in the past and never had a bad experience with them. Maybe my expectations are low, though, because I know up front that it will take a while to receive my order - it is not like ordering from Amazon with usually short and accurate delivery times.I ordered from Hifigo, but they are not honest about availability. They just said that they will ship asap without telling if they have stock or when they will have stock. Before placing the order, they told me that they will ship after 3 days. I should never blindly trust Chinese websites
Someone from Cayin can confirm whether Hifigo has stock of RU7?
Total: 6 (members: 1, guests: 5)
